Thread: Broken Link on S6 vaccum pump ?
  1. Broken Link on S6 vaccum pump ?
    May 2009
    guildford, england
    Ok, so after having a nose around to sort out a coolant leak on my troubled S6 (it was the oil cooler) i noticed that at the front of the engine, near the top, there appears to be some form of vaccum pump/switch arrangement, connected using dog bone plastic links - one of these links is broken and needs replacing. I've no idea how long this has been broken and have no idea what impact that has on the engine. i've no warning lights or noticable performance issues.
    The chaps at the dealership said it was the vaccum pump (?) and that the plastic link had to be purchased as part of a replacement unit (£140). firstly, what on earth does this kit do? and secondly, anybody got a cunning fix to avoid chipping out for the complete unit. not quite sure what next weeks problem will be, but i'll keep you posted....
  2. Re: Broken Link on S6 vaccum pump ?
    Go on give us a clue what engine it is. Please qoute your engine code from the ID label in the spare wheel bay, or in the service book. Regards Peter
  3. Re: Broken Link on S6 vaccum pump ?
    I think you are refering to the intake manifold change-over valve -N156.which will result in
    acceleration problems
  4. Re: Broken Link on S6 vaccum pump ?
    May 2009
    guildford, england
    Ok, so the engine is the 4.2, v8 - code AQJ - broken link is the right hand side of the 2 pumps. I've tried to attach a picture showing the problem. I've not noticed any acceleration problems, but then this may have been broken when i purchased the car ?
  5. Re: Broken Link on S6 vaccum pump ?
    May 2009
    guildford, england
    Zoomed in picture showing the broken plastic connector and the ball joint it should connect onto on the right hand of the two pumps (are they pumps/swtiches?) any assistance welcome, esp in finding a cheap fix!
  6. Re: Broken Link on S6 vaccum pump ?
    They are the vacuum units for the manifold change over.With the power you have on this engine,not sure if you would really notice if it was broken.
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. 2.0 tdi broken oil pump gears
    By mistycat in forum Archive posts
    Last Post: 19-09-2007, 10:08 PM
  4. AUDI S6 QUATTRO RELEASED FOR UK ORDERING
    Last Post: 14-03-2006, 09:10 PM
  5. NEW V10 AUDI S6 QUATTRO POWERS INTO DETROIT
    Last Post: 15-01-2006, 03:40 PM
