Thread: i can only select one gear in my 1.8 a3. can anyone help
  1. i can only select one gear in my 1.8 a3. can anyone help
    May 2009
    croydon,england
    hi, i can only select one gear in my audi 1.8t sport 1997, does anyone have any ideas, what problem could be... cheers ian
  2. Re: i can only select one gear in my 1.8 a3. can anyone help
    Dec 2006
    I moved your post to correct section,
    In regards to the issue, does the clutch push fully down? any noises? Which gear selects??
    Rick
  3. Re: i can only select one gear in my 1.8 a3. can anyone help
    May 2009
    croydon,england
    hi, thanks for moving this to the correct section, as for the car, it feels as though it is only selecting 3rd if i push foward and 4th backwards ( it still selects 3rd if i put the stick in reverse ), cant find any other gears.. the clutch is fine, still moves in third pulling foward. neutral is fine ... thanks for the help.. ian
  4. Re: i can only select one gear in my 1.8 a3. can anyone help
    Gloucestershire
    Hi, on top of the gearbox are the shift selctor cables, there should be two of them, on the end of these are two plastic connection boxes, these go brittle and break over time and you normally lose 1st, 3rd and 5th or 2nd 4th (6th if applicable) and reverse. The plastic connectors are around £10 and to replace them will take around 45 mins.
    HTH
    Si.
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  5. Re: i can only select one gear in my 1.8 a3. can anyone help
    Jun 2009
    Leicester
    Hi All,
    Does the apply in a case where its hard to get into 3rd gear. All gears go in but difficult to engage all gears in general. There is no play when in gear and no noises....
    Any help would be appreciated.
    Jay
  6. Re: i can only select one gear in my 1.8 a3. can anyone help
    Nov 2008
    hi there,have you tried adjusting your gearstick at all?that might help get the gears smoother
  7. Re: i can only select one gear in my 1.8 a3. can anyone help
    Jun 2009
    Leicester
    How do you mean adjust the gear stick. Do you mean the cables?
  1. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  2. World Debut For The All New Audi A3 Cabriolet
    Last Post: 01-12-2007, 06:56 PM
  3. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
