Thread: Airbag warning light
  1. Airbag warning light
    Jun 2009
    St Albans, England
    I bought a 3 year old A4 2.0T SLine and 2 days AFTER the warranty ran out (1 year dealer warranty) the airbag light has just come on. Is there anything I can check myself before taking it in to be looked at (and no doubt costing me a fair few quid) or any known problems with airbags on the B7 A4?
    Thanks,
    Paul
  2. Re: Airbag warning light
    Dec 2007
    Quote Originally Posted by Pablo99 View Post
    Thanks,
    Paul
    not sure bout b7 but b6 sometimes down to the drivers seat but you'll need to get it on vcds to get light off could be anything
  3. Re: Airbag warning light
    Dec 2007
    York
    I've got a similar problem. luckly my 2005 A4 is under warrenty (dealer 1 yr jobby).
    I have to pay £17 for a cable (not covered in extended warrently apparantly) and they are also replacing the slip ring.
    Orginally they were going to try and charge me £320, until I argued that a slip ring is not cabling. They had to go back to Audi UK to confirm and finally got back to me saying I was correct.
    Mines booked in next week for the work.
    13' Audi A6 Avant 2.0TDI Sline in Phantom Black, with heated seats, AMI and DAB
  4. Re: Airbag warning light
    selford1 Guest
    Auroan,
    Thanks for info, I have similar issue with my drivers seat airbag as checked on viacom but took to dealer for double check.
    Robbing so & so told me can only by the whole airbag assembly, having worked on car R&D I know that the wire is the weak part. Do you know part numbers of the wiring loom that you had replaced.
  5. Re: Airbag warning light
    Dec 2007
    York
    Quote Originally Posted by selford1 View Post
    Auroan,
    Not yet, car hopefully gets fixed (on the third attempt by York Audi ) I doubt they will give me the part number of the replaced item.
    But I am going to ask for the broken bits back.....
  1. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  4. dripping when opening doors and airbag warning light
    By luckda in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-03-2008, 01:07 AM
  5. Airbag warning light
    By funkymonkey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-03-2008, 07:25 PM
