Thread: Power steering fluid leak!
  1. Power steering fluid leak!
    Jun 2009
    United Kingdom
    I have a 96 cab and have found a leak to be coming from the seals of the power steering rack. If the leak continues the brake light in the dash flashes. I have had the gaiter replaced but this obviously didnt fix it and it seems that the seals have to be replaced (v expensive so my garage tells me as its v fiddly) I have been through over 5 bottles of fluid the recommended g00200 stuff and tried 'stop leak' fluid a few times but no joy.
    Anyone come across this before or have any advice before I go and hemorrhage money at the garage?
  2. Re: Power steering fluid leak!
    Jan 2009
    towcester northants
    you will have to fit a new rack
    you will need to flush the system as well to get rid of the residue of stop leak etc
  3. Re: Power steering fluid leak!
    Jul 2009
    rotherham uk
    Quote Originally Posted by towcestervag View Post
    Hi All Newby here. (1998 Audi Cabriolet) I have a similar problem nothing to do with rack or gaitors it is where the steering column joins the brake master cylinder that I have got the leak but it appears to be a small hole underneath power steering part that attaches brake master cylinder but cant see no way of sealing it can it be to back pressure as I have had a new power steering pump fitted. could there be an air lock or something that is causing this problem as it hasnt happened before? All help apprecited...
    Paul.
  1. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
  2. Topping Up Power Steering Fluid
    By tixy in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2007, 11:37 PM
  3. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
  4. power steering fluid?
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-03-2007, 10:45 PM
  5. Power steering fluid leak
    By tBoris in forum Audi A4 - Archive Topics
    Last Post: 19-09-2006, 10:12 AM
