Thread: Audi Coupe 2.3 20v Starting problems
  1. Audi Coupe 2.3 20v Starting problems
    Jun 2009
    Southampton England
    hi
    i have just brought a 1991 2.3 20v quattro. but she has a few problems. when it is cold it starts mostly with out any probs but when its warn is takes lots of cranking to get her to start. the prevous owner put new coil leads plugs on it etc no change.
  2. Re: Audi Coupe 2.3 20v Starting problems
    Gwent
    probably a good place to start is to check for ECU fault codes. This can be done fairly easily with a few bits of wire and a l.e.d. or 1.2watt 12v lamp:
    http://www.20v.org/engprob.htm#faultcodes
    a problem with the temp sender for the ecu is a possibility, the one at the rear of the cylinder head. It is possible for this to be faulty but not show up as a stored fault.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  2. Audi Coupe 2.3e 1990 Problems
    By dal007 in forum 80 - 90
    Last Post: 26-03-2009, 12:37 AM
  3. High Performance Audi Tts Debuts In Detroit
    Last Post: 15-01-2008, 09:19 PM
  4. Road-ready Audi R8 super car wows Paris show
    Last Post: 28-09-2006, 09:46 PM
  5. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
