Thread: Service Checklist
Results 1 to 10 of 12
  1. Service Checklist
    Mar 2007
    I recently put together a maintenance report checklist for my Passat TDi which I thought I could share with you. I'm not recommending anything its purely something I've done for my own personal use but it may come in useful for others who do their own services. There are quite a few omissions, namely those which are checked as part of the yearly MOT, but if you have any suggestions or additions from experience or other which you think could be included I would be pleased to hear from you,. Enjoy
    Routine Maintenance Report
    Vehicle DetailsDateMileageService Schedule 5,000 Mile Service 5,00015,00025,00035,00045,00055,00065,00075,00085,00095,000105,000115,000125,000135,000145,000155,000165,000175,000185,000195,00010,000 Mile10,00030,00050,00070,00090,000110,000130,000150,000170,000190,00020,000 Mile Service 20,00060,000100,000140,000180,000220,00040,000 Mile Service40,00080,000120,000160,000200,000Timing Belt Renewal60,000120,000180,0005,000 Mile Service10,000 Mile Service1. Add Engine Flush To Oil1. Add Engine Flush To Oil2. Replace Engine Oil & Filter 2. Replace Engine Oil & Filter 3. Check Tyre Condition - Replace if Necessary3. Check Timing Belt For Wear & Serviceability4. Add Diesel Fuel Treatment5. Check Brake Pads For Wear & Serviceability6. Replace Wiper Blades7. Check Tyre Condition - Replace if Necessary8. Reset Service Interval Display20,000 Mile Service40,000 Mile Service1. Add Engine Flush To Oil1. Add Engine Flush To Oil2. Replace Engine Oil & Filter 2. Replace Engine Oil & Filter 3. Check Manual Transmission Oil Level3. Check Manual Transmission Oil Level4. Drain Water From Fuel Filter4. Replace Fuel Filter5. Renew Engine Coolant - (Flush System)5. Renew Engine Coolant - (Flush System)6. Check Timing Belt For Wear & Serviceability6. Check Timing Belt For Wear & Serviceability7. Check Auxiliary Drive Belt For Wear7. Check Auxiliary Drive Belt For Wear8. Renew Pollen Filter8. Renew Pollen Filter9. Check Brake Pads For Wear (Detail Below)9. Renew Air Filter10. Renew Brake Fluid10. Renew Fuel Filter11. Check Underbonnet For Hose & Fluid Leaks11. Check Power Steering Hydraulic Fluid Level12. Add Diesel Fuel Treatment12. Check Brake Pads For Wear (Detail Below)13. Replace Wiper Blades13. Renew Brake Fluid14. Check Windscreen Washer System14. Check Underbonnet For Hose & Fluid Leaks15. Lubricate All Hinges & Locks15. Check Underbody Protection - Repair as Necessary16. Check Engine Management Self Diagnosis16. Add Diesel Fuel Treatment17. Check Tyre Condition - Replace if Necessary17. Replace Wiper Blades18. Reset Service Interval Display18. Check Windscreen Washer System19. Lubricate All Hinges & Locks20. Check Engine Management Self Diagnosis21. Check Tyre Condition - Replace if Necessary22. Reset Service Interval DisplayBrake Details (mm)CommentsNS / FInnerOuterOS / FInnerOuterNS / RInnerOuterOS / RInnerOuterBrake DiscsNS / FOS / FNS / ROS / RNext service Target Mileage Next Service5,00010,00020,00040,00060,000 Timing Belt / Drive Belts
    Mar 2007
    OOps that didn't work, I'll try again.
    Routine Maintenance ReportVehicle DetailsDateMileageService Schedule 5,000 Mile Service 5,00015,00025,00035,00045,00055,00065,00075,00085,00095,000105,000115,000125,000135,000145,000155,000165,000175,000185,000195,00010,000 Mile10,00030,00050,00070,00090,000110,000130,000150,000170,000190,00020,000 Mile Service 20,00060,000100,000140,000180,000220,00040,000 Mile Service40,00080,000120,000160,000200,000Timing Belt Renewal60,000120,000180,0005,000 Mile Service10,000 Mile Service1. Add Engine Flush To Oil1. Add Engine Flush To Oil2. Replace Engine Oil & Filter 2. Replace Engine Oil & Filter 3. Check Tyre Condition - Replace if Necessary3. Check Timing Belt For Wear & Serviceability4. Add Diesel Fuel Treatment5. Check Brake Pads For Wear & Serviceability6. Replace Wiper Blades7. Check Tyre Condition - Replace if Necessary8. Reset Service Interval Display20,000 Mile Service40,000 Mile Service1. Add Engine Flush To Oil1. Add Engine Flush To Oil2. Replace Engine Oil & Filter 2. Replace Engine Oil & Filter 3. Check Manual Transmission Oil Level3. Check Manual Transmission Oil Level4. Drain Water From Fuel Filter4. Replace Fuel Filter5. Renew Engine Coolant - (Flush System)5. Renew Engine Coolant - (Flush System)6. Check Timing Belt For Wear & Serviceability6. Check Timing Belt For Wear & Serviceability7. Check Auxiliary Drive Belt For Wear7. Check Auxiliary Drive Belt For Wear8. Renew Pollen Filter8. Renew Pollen Filter9. Check Brake Pads For Wear (Detail Below)9. Renew Air Filter10. Renew Brake Fluid10. Renew Fuel Filter11. Check Underbonnet For Hose & Fluid Leaks11. Check Power Steering Hydraulic Fluid Level12. Add Diesel Fuel Treatment12. Check Brake Pads For Wear (Detail Below)13. Replace Wiper Blades13. Renew Brake Fluid14. Check Windscreen Washer System14. Check Underbonnet For Hose & Fluid Leaks15. Lubricate All Hinges & Locks15. Check Underbody Protection - Repair as Necessary16. Check Engine Management Self Diagnosis16. Add Diesel Fuel Treatment17. Check Tyre Condition - Replace if Necessary17. Replace Wiper Blades18. Reset Service Interval Display18. Check Windscreen Washer System19. Lubricate All Hinges & Locks20. Check Engine Management Self Diagnosis21. Check Tyre Condition - Replace if Necessary22. Reset Service Interval DisplayBrake Details (mm)CommentsNS / FInnerOuterOS / FInnerOuterNS / RInnerOuterOS / RInnerOuterBrake DiscsNS / FOS / FNS / ROS / RNext service Target Mileage Next Service5,00010,00020,00040,00060,000 Timing Belt / Drive Belts
    Mar 2007
    It dosn't seem to be working. This is an excel file ........... any suggestions for posting
    Mar 2007
    Ok so that didn't work either. If anybody wants a copy pm me and i'll send you the file (Note: File is xls.).
    Mar 2007
    It would be a good idea to offer it as an Opendocument spreadsheet file (.ods) as supported by Openoffice as well. Not everyone had excel but most people can download Openoffice for free.
    Mar 2007
    Cornwall
    You can upload the file as an attachment [paperclip icon] as long as it is less than 19.5k in size.
    You could also save the file in csv format so forum members can use their preferred spreadsheet or database to open the file.
    Guy
    Mar 2007
    Had to zip the files, let me know if they don't work / open, I'm a bit green when it comes to uploading files etc.
    Mar 2007
    Cornwall
    Hi Foxclub
    It works fine in all three formats.
    Thanks,
    Guy
  9. Re: Service Checklist
    Mar 2008
    cheers Foxclub,
    very helpful.
  10. Re: Service Checklist
    Sep 2007
    Is this something you have made up yourself or is it out of a service manual?
    Cheers,
    Jon
  1. A3 needs a service
    By dumpee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-05-2007, 10:48 AM
  2. A3 service
    By dumpee in forum Audi A3 - Archive Topics
    Last Post: 23-04-2007, 05:25 PM
  3. The first service
    By Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-04-2007, 12:37 PM
  4. Service now
    By phils2309 in forum Passat - Archive Topics
    Last Post: 01-12-2006, 03:05 AM
  5. A4 Air-Con Service
    By kitt247 in forum Audi A4 - Archive Topics
    Last Post: 28-07-2006, 05:00 PM
