Thread: 00515 camshaft position hall sensor g40 - no signal Really need help please !
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Feb 2011
    Barnoldswick
    Problems with car 1997 a3 1.6 sport
    - Only reving to 5000rpm when in a gear, in neutral it will rev to approx 6500rpm
    - When pulling away from lights etc loss of power, trys to stall, (only happens when car is upto temp) ok when cold
    - Revs take a bit longer than normal to come down to idle
    - strong smell of unburnt fuel
    - loss of power
    - Temp guage moves between 60 - 90 ( I have replaced senor with no joy)
    Only codes showing up is
    Please can some1 help me out with this, ie - where is the camshaft sensor located and can I take it out to clean etc.
    Any help will be much appreciated.
    Regards
  2. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Feb 2011
    Barnoldswick
    update people,
    Ran the car for a while, temp went upto 90 deg and stayed there.
    Pluged the scanner in and still got the same fault
    Every so ofter the lambda sensor code woud come up saying - low end
    I understand this is to do with the misture running rich ? am i right ?
    Regards
  3. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    133 Post(s)
    1987 Post(s)
    The sensor (part number 06A 905 161 B, £112.27 from Audi) requires the upper cam pulley to be removed (or pulled nearly off) so it can be changed.
  4. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Feb 2011
    Barnoldswick
    Thanks crasher!,
    How do you go about pulling it nearly off? is it a hard job ?
  5. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    133 Post(s)
    1987 Post(s)
    If you pull the upper pullet right back along the camshafts woodruff key you may be able to get the sensor out from between the chopper blade on the pulley.
  6. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Dec 2010
    South Wales
    Sorry to jump on this thread but I've got the same problem. I've changed the cam sensor but same error comes back? What els could it be? I've changed the coil. Could it be worth changing the plugs?
    Car failed the MOT on emissions so am desperate to get this sorted now.
  7. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    133 Post(s)
    1987 Post(s)
    What is the exact fault code you are getting and the cars details?
  8. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Dec 2010
    South Wales
    Same as above crasher 00515. It's a 1.6 2000 A3.
    Runs ok cold but misfires slighty when upto temp.
  9. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    133 Post(s)
    1987 Post(s)
    There are two versions of the fault code, which one do you have?
    00515 Hall sender
    1) G40 No signal
    2) Implausible signal
  10. Re: 00515 camshaft position hall sensor g40 - no signal Really need help please !
    Dec 2010
    South Wales
    It's the Implausible signal one.
  1. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  2. 00515 Hall Sensor G40 No Signal - HELP
    By mitov in forum VCDS - General Questions
    Last Post: 12-12-2010, 03:16 PM
  3. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  4. Please Help Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2008, 12:51 AM
  5. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
