Thread: DIS stalk retrofit - question?
Results 1 to 10 of 17
  1. DIS stalk retrofit - question?
    OXON, UK
    Hi Folk's,
    I've managed to aquire a wiper stalk for my '04 A4 TDI 130 Sport Avant with the DIS buttons. However, I only have the shareware version of VAG COM.
    My question is, if I fit the DIS stalk will it operate as a normal wiper stalk until I am able to get the car re-coded with a full version of VAG COM?
    Thanks for any info.
  2. Re: DIS stalk retrofit - question?
    May 2007
    knee deep in clunge
    14 Post(s)
    yes
  3. Re: DIS stalk retrofit - question?
    Feb 2009
    Note you may need to change your steering control unit!! depends on the version you have.
    Walter.
  4. Re: DIS stalk retrofit - question?
    OXON, UK
    Oh, I was under the impression that all the steering control units could do DIS, but not necessarily cruise.
    Cheers.
  5. Re: DIS stalk retrofit - question?
    paul20v Guest
    isnt the dash internals different
    or am i being a plank.
    if not whats involved with this mod.
    sorry for the hijack
    its just better than starting another thread
  6. Re: DIS stalk retrofit - question?
    Jul 2008
    can i ask how much they charged? i wanted to get this done as well
    2001 AUDI A4 1.8T SPORT
  7. Re: DIS stalk retrofit - question?
    May 2007
    knee deep in clunge
    14 Post(s)
    all steering column electrics control units allow dis switch function
    use this link https://www.vwaudiforum.co.uk/forum/s...ad.php?t=52211
    one day the mods will make it a sticky and save me having to cut and paste
  8. Re: DIS stalk retrofit - question?
    OXON, UK
    Thanks for clearing that up a8.
    BTW, are you aware that the attachments in that thread are not working?
    Cheers.
  9. Re: DIS stalk retrofit - question?
    May 2007
    knee deep in clunge
    14 Post(s)
    yes i am,they were only photo's of the fitment and you don't need them as the guide is pretty comprehensive and i am always around the forum for help
  10. Re: DIS stalk retrofit - question?
    HELLAS (GREECE)
    I've just retrofited myself Cruise Control and DIS Stalk.
    My car had factory installed these modules:
    - Steering Wheel: 8E0 953 549 N
    - Instruments: 8E0 920 900 K
    - Central Electronics: 8E0 907 279 C
    I used the following parts:
    - Switch for wipers/DIS: 4E0 953 503 F 4PK (79,03 euro)
    - Switch for Cruise Control: 4E0 953 521 B (28,96 euro)
    - Trim lower part for Cruise Control: 8E0 953 512 P 6PS (30,68 euro) (black)
    - Screws (x2) for CC stalk: N 909 068 02 (0,24 euro)
    I made the coding with Vag COM and the Cruise Control working...
    After made coding for the DIS I have the following information (see attatchment photos) on the display (when I press the reset button). Is it normal?
    I also bought the following parts to retrofit the water sensor (all these costs 26,82 euro):
    - Water Level Sensor: 7M0 919 376
    - Flat Contact: 1J0 973 202
    - o-Ring: 7M0 919 382
    - Repair Cable for Flat Contact (x2): 000 979 133A
    - Repair Cable for Instruments T32/1: 000 979 009A
    So, I need some help about the correct location of the pins.
    I know that I must connect T32 blue connector of intruments cluster pin 1 to water sensor.
    But how?
    According ELSAWIN (see attatchment photo) the connection is: T32/1 -> T17/9 -> Water sensor and Water Sensor -> T17/10. Is this OK? I must connect two wires from water sensor to T17 and one wire to T32/1?
  1. Answer A Question & Ask Any Question?
    Last Post: 23-11-2011, 01:51 PM
  2. DIS setup question
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-05-2009, 09:49 PM
  3. A6 Cruise Retrofit question
    By Redzer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2009, 11:39 AM
  4. Dis Retrofit
    By rigsby29 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 11:58 AM
  5. DIS - easy question for you
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 24-02-2007, 11:59 AM
