Thread: 2.0 TDI BLB Engine Oil pump failure
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Exclamation 2.0 TDI BLB Engine Oil pump failure
    Jun 2009
    Hamphire
    Hi all,
    On my fourth Audi and concerned that they 'don't make em like they used to !'
    - My Oil pump has just gone in my '55 plate' A4 at about 97,000 miles and I now know of another 6 that have gone at a similar time in various Passat's & Audi's with this 2.0ltr TDI Engine.
    Unfortunately, my local Audi dealaship have informed the that the parts alone will cost nearly 9k & so effectively the car is a right off with no residual value & no recompence to my Insurance.
    - Just wondered if any other forum members have suffered the same problem so that I can gauge the scale of this problem and if any one has any idea's of the best way to get the car back on the road ASAP.
    Apparently it needs a new engine, turbo & exhaust system as a minimum !!
    P
    2 0 0
  2. Re: 2.0 TDI BLB Engine Oil pump failure
    Jul 2009
    Grays
    Yep, i got it now, but i have found the problem before the mechanism gone, was very noisy. Dealers ask for nearly 1000 FOR PARTS and 7 hours labour, £115/hour. Sad..
    3 0 0
  3. Re: 2.0 TDI BLB Engine Oil pump failure
    Quote Originally Posted by zenonek View Post
    What were the symptoms? If you could email me ASAP please ce.glover@tiscali.co.uk it would be much appreciated.
    Tonight, mine sounded really noisy when I got home. When trying to restart, it runs for a minute then cuts off. Same when I tried a second time. I have given up trying to prevent damage.
  4. Re: 2.0 TDI BLB Engine Oil pump failure
    Jan 2009
    Stoke-on-Trent
    Oil pump failure is common on the 2.0TDI.
    Either the shaft driving the pump from the balance shaft rounds off or the balance shaft drive gears eat themselves.
    Pretty sure VWG UK are aware of the problem and have been for some time
    Dave
    Servicing, Repairs, Diagnostics and Re-mapping in Staffordshire
  5. Re: 2.0 TDI BLB Engine Oil pump failure
    Aug 2009
    Suffolk UK
    I have the same problem. 05/55 A4/2.0 tdi 140, BLB engine, 100k. Low oil pressure warning yesterday, towed in to Audi, so far 5hrs labour to inspect, the turbo has gone and there are also engine problems that are not yet clear.
    I will keep you up to speed, but would be interested in how you are resolving the failure and whether Audi contribute.
    This is my 5th Audi and I have done several hundred thousand miles in them over the last 25 years. I still have the 4th - a 1999 A4 1.9 tdi which has covered 230k. I likewise have not had previous significant problems.
  6. Re: 2.0 TDI BLB Engine Oil pump failure
    Aug 2009
    cambridge
    05 A4 avant 20.tdi, with 93K, engine type is BLB
    I have the same issue...low oil pressure warning light, noisy rattling engine. Local garage has just diagnosed oil pump balancer shaft assembly....£800 for the part and another £500 to fit......ouch.
    Audi UK are not interested and advise that at 5 years old and 'above av mileage' that it's my problem even tho its got a FSH at main dealers. I'd also dispute the av mileage thing for users of the A4
    I'd be interested to find if this is a common problem, this is the worst car i've ever owned , I've had loads of problems inc a air con compressor failure last year which was going to be a £700 part until I managed to find one on ebay
  7. Re: 2.0 TDI BLB Engine Oil pump failure
    Aug 2007
    I was reading a copy of Audi Driver (or something similar) a couple of months back and there was an article about this. They said what a stupid design it was as the old pump design worked perfectly and the shaft system is an accident waiting to happen.
  8. Re: 2.0 TDI BLB Engine Oil pump failure
    Jun 2009
    Hamphire
    Do you have a copy of the artical ?
  9. Re: 2.0 TDI BLB Engine Oil pump failure
    Aug 2007
    Sorry, I don't. It was in garage's waiting room.
    Maybe you could find it on their web site:
    http://www.audidrivermag.co.uk/
  10. Re: 2.0 TDI BLB Engine Oil pump failure
    Dec 2008
    Midlands
    Welcome to the forums! Enjoy
    Audi A4 1.8T Quattro Convertible 200+ BHP
    See it here and let me know what you think! : https://www.vwaudiforum.co.uk/forum/s...ad.php?t=81930
    Youtube Channel: www.youtube.com/555senna
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  3. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
