Thread: Faulty indicator but the bulb is fine.
  1. Faulty indicator but the bulb is fine.
    crichten Guest
    Hey guys/Gals
    Ive got a problem come up with the nearside front indicator.
    The bulb is all in order however its not well 'indicating' there has been no fault come up on the car.
    I am kinda stumped as to what it could be, i've checked the fittings though.
    Chris
  2. Re: Faulty indicator but the bulb is fine.
    paul20v Guest
    have you checked the multiplug on the rear of the light.
  3. Re: Faulty indicator but the bulb is fine.
    Apr 2009
    Cardiff
    Could be faulty switch contacts.
  4. Re: Faulty indicator but the bulb is fine.
    Jul 2008
    i had the same problem, its dirty contacts get a tissue put some white spirit on it and clean the contacts in the bulb holder, mine worked fine after that
    2001 AUDI A4 1.8T SPORT
  5. Re: Faulty indicator but the bulb is fine.
    paul20v Guest
    Quote Originally Posted by keithwigley View Post
    switch contacts would cause left or right not an individual light .
  6. Re: Faulty indicator but the bulb is fine.
    crichten Guest
    Yup,
    As above It was a scewy connection.
    Took the cluster out (well tried to anyone know how to remove the cluster wiring loom?) I put the bulb holder back in and it just worked again :P
  7. Re: Faulty indicator but the bulb is fine.
    21stCentury Guest
    I've had this a couple of times. Each time I removed the bulb, cleaned the contact surfaces, then gently bent the contact tags just slightly to make them press more tightly onto the bulb contacts and refitted the bulb.
  8. Re: Faulty indicator but the bulb is fine.
    crichten Guest
    Got the wiring loom out, lifted the top clip up with a screwdriver and it un clipped nicely.
  1. "How To" change a Polo headlamp bulb
    By KeithS in forum Volkswagen
    Last Post: 03-01-2016, 09:18 PM
  2. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  3. Please Help Problem with xenon bulb on 2005 a3 tdi
    By Makavelli2009 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-04-2011, 11:35 AM
  4. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  5. Please Help Sidelight bulb change
    By billiethezwerg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2009, 01:22 PM
