Thread: calling all mk5 experts, 1.4 with probs
  1. calling all mk5 experts, 1.4 with probs
    Aug 2009
    manchester
    hi all, just spent an hour reading posts after a search but cant find anything similar to our prob.
    car is 56reg golf (october 2006) 1.4s. have got the car booked in to be looked at under warranty in just over a weeks time.
    after 22,000 miles we have:
    rear door handle sticks, front brakes clunk (i suspect a sticking caliper) and one other very interemmitant fault.
    when driving in 5th at around 45mph the car will suddenly lose all power
    (as if engine has stalled, foot to floor on accelerator does nothing at all the car will just continue to slow down) the only way to restore power is by droping down a gear to 4th.
    now this has happened only a handful of times in our ownership. maybe 6-7 times in the last 8 months.
    ps it is not the car struggling as when drinving up a hill. it does it on flat roads and even going down hill. no pattern has emerged either.
    As said above the car is booked in to be looked at, just hoping for a bit of info from those in the know in case they tell us "no fault were found on the fault reader" after having the car all day
    especially as the waranty runs out in october want to get any nightmares sorted out now at vw's expense
    sorry for the essay but all help greatly appreciated
    cheers
  2. Re: calling all mk5 experts, 1.4 with probs
    Aug 2009
    manchester
    Quote Originally Posted by Keith@APR View Post
    From your description of the running issue, it sounds like you have a high pressure fueling system issue. The dealers are well versed in the repair and VW has released quite a bit of documentation regarding the failures.
    You are looking at a simple sensor replacement up to a new high pressure fuel pump. Either way, with the car reacting the way it is, there should be several DTC's referencing the issues.
    What is essentially happening, is that the ecu is detecting an operating condition is doesn't like and is cutting spark to the engine for a period of time until the bad condition is cleared up.
    The most common example is a lower amount of fuel pressure in the fuel rail than specified by the ecu. Once the variance becomes great enough, the ecu says "Let's slow down and get that rail pressure back up to where it needs to be." Once rail pressure is restored after a period of usually a few seconds, power returns.
    thanks for a very quick reply with a load of info there, any idea if a fault code should have been stored? ps any links to threads on this fault
    cheers keith
    oh pps what are DTC's - EDIT googled it (fault codes)
  3. Re: calling all mk5 experts, 1.4 with probs
    Coventry
    any outcomes yet? did you get it fault read before it went to the dealers?
  4. Re: calling all mk5 experts, 1.4 with probs
    Aug 2009
    manchester
    Quote Originally Posted by golfmk5gttdi View Post
    its not been yet, the appointment is on the 18th- had to wait for courtesy car!
    not had it fault read by anyone else.
  5. Re: calling all mk5 experts, 1.4 with probs
    Coventry
    there are members in manchester which maybe able to help.
  6. Re: calling all mk5 experts, 1.4 with probs
    Aug 2009
    manchester
    if i had it read 1st, would vw still be able to see the codes? car goes in on tuesday
  7. Re: calling all mk5 experts, 1.4 with probs
    Coventry
    yes
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Please Help New Owner -> 1.4 Ibiza Chill 2001 has a few Probs
    By Debbie Parker in forum Ibiza - Cordoba
    Last Post: 17-06-2009, 07:08 PM
  4. leon 1.4 16v engine power probs
    By gingerben in forum Leon
    Last Post: 06-04-2008, 01:16 PM
  5. VW Polo 1.4 auto 2000 Engine management light probs
    By M'lady in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2007, 03:16 PM
