Thread: My A4 110SE TDi crunches into 4th gear, why?
  1. Unhappy My A4 110SE TDi crunches into 4th gear, why?
    Jun 2008
    Hello,
    My 1997 A4 110SE TDi crunches into 4th gear, why?
    I have been told by 'a mate' that the syncro is broken, but it is only for fourth gear that it cruches.
    Do gears have individual syncros?
    It goes into gear no problem, just make a crunch sound when it does.
    The car is not high miles as it has 'only' done 87500 miles and was regularly serviced.
    Any ideas?
    Sean
  2. Re: My A4 110SE TDi crunches into 4th gear, why?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi,yes,the synchro ring for 4th gear is either worn out,or cracked in half etc.May help if you engage this gear gently for now.Not a common fault especially for that mileage.
  3. Re: My A4 110SE TDi crunches into 4th gear, why?
    Jun 2008
    Hello,
    Thanks Alan. Is it cheaper to fix the box or replace it do you reckon?
    If repairing, should I get the other syncros changed at the same time?
    I know 2nd gear is a common fault?
    thanks again! Sean
  4. Re: My A4 110SE TDi crunches into 4th gear, why?
    Nov 2008
    20 Post(s)
    Hi Sean,never had the misfortune of this problem myself.It all depends on what box you would replace it with,as in,is it a refurbished box itself or is it out of a scrapped vehicle? If you can locate a local mechanic capable of the job,maybe worth pricing both options.
    If you do go ahead and get it repaired,get them to inspect the rest of the Synchros.It may be they are fine.You will not know till its stripped thats the thing.But you dont have to replace all if you want to keep costs down.You can go to extremes and throw new parts at it!Cheers!
  5. Re: My A4 110SE TDi crunches into 4th gear, why?
    Jun 2008
    Thank Alan,
    My local garage owner used to work for VW and knows the engine well. I have asked for a quote for a repair, which he is still working out. I am sure he will check the other rings, but I will ask him to check.
    I will keep the post updated for others.
  6. Re: My A4 110SE TDi crunches into 4th gear, why?
    Nov 2008
    20 Post(s)
    Good Luck,hope its not too expensive!
  1. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
