Thread: Warning when trying to claim on AA warranty
Results 1 to 8 of 8
  1. Warning when trying to claim on AA warranty
    Feb 2009
    I turned the temp down on my climate control and nothing happened, it just stayed as warm as it was before, so as i was passing my local garage i popped it in(its a reliable garage, they only tell you something wants doing if it really does) they have a quick look and tell me some valve is probably blocked as presssure not equalising and tells me it might have damaged pump but not 100% positive on this one.
    I have AA parts and labour warranty and was pretty sure my pump was covered, i went home checked paperwork and low and behold it is.
    I rang AA to start a claim who then inform me that i cant claim because garage looked at it first.
    To put it simply if you have AA warranty they say an AA roadpatrol have to look at the car before anybody else or they wont honour warranty.
    What a load of bull i have been with them for 10 years covering both mine and my wifes car i wont be with them ever again.
  2. Re: Warning when trying to claim on AA warranty
    May 2009
    uk
    thats rubbish. i'd not leave it at that!
  3. Re: Warning when trying to claim on AA warranty
    Feb 2009
    tried to appeal, they said it was standard policy and i should have read the paperwork when i signed up.
    i ponted out that it was 10 years ago, they said it was on my renewal, i ponted out that nobody reads them they just check the amount seems reasonable and pays it.
    They are just not interested in looking after customers they just want your money with no intention of paying out when they are supposed to.
    As soon as i figure out the best method for taking this further i will be doing so.
  4. Re: Warning when trying to claim on AA warranty
    Feb 2009
    Liverpool, UK
    I had the same problem with Warranty Direct, they said my master cylinder fault was a pre existing problem and that i knew about it before took out the policy with them so they wouldnt pay out.
    It seems a similar story with all of these warranties they are quick enough to take your money but dont want to pay out when you have a a genuine claim.
    Im glad you pointed out this issue with the AA warranty as i left warranty direct and took out a policy with the AA instead for mine and the wifes car. I am going to make sure i call out an AA patrol no matter how small the issue might be with my Passat.
  5. Wink Re: Warning when trying to claim on AA warranty
    Hi you might well be able to provide a counter argument here.The air con that is fitted to your passat requires dedicated test equipment to identify the problem the AA patrols do not have access to the necessary equipment to check the pressure in the system or to check for any air con diagnostic fault codes therefore they would refer you to a specialist anyway.Call them out and see
  6. Re: Warning when trying to claim on AA warranty
    Feb 2009
    K. anything is worth a try. waiting for a reply from an official complaint i have submitted to them i will put that point forward. ta
  7. Re: Warning when trying to claim on AA warranty
    Feb 2009
    well i got my reply from the ******** Association
    Thank you for your email.
    Your email has been logged against the above Service Request Number.
    We are sorry that you have been put to the trouble of contacting us.
    I can confirm that your claim has been rejected under the Breakdown Repair
    Claims Terms and Conditions.
    In the event of a breakdown you have to contact The AA, we would then send a
    patrol out to assist you and if he couldn¿t repair the vehicle we would organise
    the patrol to recover the vehicle to the garage and arrange the repair if it was
    covered under the Terms and Conditions, as you drove the car to the garage
    yourself the claim would be void.
    You can put your complaint in writing and send it to the following address, the
    department will look into your complaint and contact you direct.
    10 years i have never complained and always paid my renewal - never again will i use the AA
  8. Re: Warning when trying to claim on AA warranty
    Pembrokeshire
    22 Post(s)
    surely theres been a misunderstanding here. you WERE going to take your car to a garage, but called the AA first, who advised you that the claim would be void if you did, so you didnt take your car to the garage , but now they think you have.
  1. 1.8T oil pressure on motorways
    By pippip in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2009, 01:03 PM
  2. Making a warranty claim for corrosion, any experience?
    By 54A4Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2008, 07:57 PM
  3. Possible Trim warranty claim ??
    By ChuckH in forum Chat - Anything with wheels
    Last Post: 06-04-2008, 10:56 PM
  4. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  5. WARRANTY
    By fatblokescanfly in forum The Commercial Range
    Last Post: 22-01-2006, 06:03 PM
