Thread: Door handle broken
Results 1 to 8 of 8
  1. Door handle broken
    Jun 2009
    Manchester, UK
    My 94 Avant TDi has a broken drivers side interior door opening handle
    The handle just pulls out and doesn't engage the latch
    At the moment I have to wind down the window and open the door from the outside (which is annoying as I always forget )
    Does anyone have a procedure for repairing/replacing the handle?
  2. Re: Door handle broken
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi,check the cable hasn`t come adrift of the interior handle,or a locating tag hasn`t broken off on the cable first,causing it to not operate the latch,more than likely to be the problem.Just remove the door trim panel .Cheers.
  3. Re: Door handle broken
    Jun 2009
    Manchester, UK
    thanks guys
    i may be being dense but i can't figure out how to get the fascia panel on the door off - it's either stuck or i'm doing it wrong
  4. Re: Door handle broken
    Nov 2008
    20 Post(s)
    Check all around the edge of the trim panel for small screws,i cant comment on your particular year,as i had an `88 model,but there was a screw inside the interior handle part,to un-clip -push forward,you`ll then see the cable.Under the door `pull` handle you may see a plastic panel,un-clip and 2 screws under it.And then,if you have elec.windows,the whole panel will lift out.As mentioned,the panel is removed from the door by lifting it `UP`.Hope this is of help!
  5. Re: Door handle broken
    Nov 2008
    20 Post(s)
    Hi StompOn,you beat me too it!
  6. Re: Door handle broken
    Gwent
    I did a bit of a 'how to' for the coupe, should be some similarities?:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=32863
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  2. Removing boot trim to empty broken glass
    By gfoden in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2008, 12:21 PM
  3. car easily broken into advice needed
    By elninio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2007, 09:24 AM
  4. T4 Transporter mistery broken part
    By ohdesign in forum The Commercial Range
    Last Post: 02-07-2007, 08:51 PM
  5. vw transporter T4 mistery broken part
    Last Post: 02-07-2007, 08:48 PM
