Thread: A4 Avant 2.5 TDi Quattro fuel economy
Results 1 to 10 of 15
  1. A4 Avant 2.5 TDi Quattro fuel economy
    May 2009
    Glasgow
    First post here, please be nice!
    The car: A4 Avant 2.5 TDi 180 Quattro 5spd Auto Tiptronic, 03 Plate.
    The problem: Average 29 MPG.
    Ok, I know I shouldn't expect 50 MPG, but I've had the car 2 months, and I'm driving it very gently. I drive a mix of motorway and town, but with more motorway than town, maybe 65% motorway.
    I thought I should expect closer to 35 MPG average, What Car online says 25.9 in town, 46.3 out of town, average 35.3. I reckon I'm 5 MPG lower on each of those, and my average on motorway alone was around 35, so possibly 11 MPG down on expected motorway consumption.
    My numbers for average are calculated when filling the car up, so are accurate. DIS reports about 1 MPG better than my calculation. I'm not carrying heavy loads around.
    The car is in great condition, full dealer service history, 97,000 miles, all fluid levels have been checked and are ok.
    Is there something I should be aware of? Anything obvious I can check? Any advice?
  2. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Feb 2009
    you should be aware that alot of audi auto gearboxs are a time bomb waiting to cost £2000 to fix.
    29mpg is really bad, my 1.9tdi was slightly sluggish and had bad mpg when i bought it because it had been owned by a lady driver for 3 years and hadnt been driven hard only town driving so i drove it hard for a week or so and the problem got better as the turbo de-coked itself.
  3. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Dec 2008
    I had a similar experience with my Allroad 2.5 tiptronic... my solution? Changed it for an A4 Avant tdi sport manual - averages over 40mpg mixed and up to 55 on a longer run. Much happier now and don't have the constant worry about whether the gearbox is gone give up!
    Ex - Allroad Tdi Limited Tipronic
    Now - A4 AVANT 1.9 TDI SPORT S-Line
  4. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Sep 2008
    i average about 35mpg from my 2.5tdi quattro sport avant, couldn't be any happier!! don't forget they're a big car and a 2.5v6 motor, considering this 29mpg is ok-ish and maybe it's because yours has high miles now and ready for some work on the engine? i dunno tbh
  5. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Sep 2008
    6 Post(s)
    Quote Originally Posted by mark shutt View Post
    I wouldn't say high miles. The V6 unit should last the life of the car if properly maintained.
    I'd be inclined to check obvious things first. Possibly fit K&N standard air filter, check EGR valve and turbo aren't blocked with carbon build up. Also Air Mass Filter may be faulty.
    You can also run a can of Forte diesel conditioner straight into the fuel filter and drive the car hard. There should be a fair bit of black smoke initially until it clears. Replace fuel filter afterwards.
    I have the smaller engine (AKN) 150bhp Quattro Avant - but regularly return 45mpg on A-class roads. Town driving is a different story.
    2016 BMW i3 REx (80k)
  6. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Sep 2008
    i know the 2.5 should last a lifetime but it'll still get choked up just like any other engine and after 100k would probebly need a good service/decoke.
    not sure if diesels actually suffer as much as petrols and what with todays cleaner fuel and more efficiant engines i'm not even 100% sure just airing my views.
  7. Re: A4 Avant 2.5 TDi Quattro fuel economy
    Lincolnshire
    Mine averages 35mpg on a good steady run (180 Quattro Sport Avant), which for the performance i think is pretty good. Yours is auto box which will slightly lower your mpg due to torque converter action.
  8. Re: A4 Avant 2.5 TDi Quattro fuel economy
    May 2009
    rhodesia, nottinghamshire
    as spartacus says put some forte through engine, it's very good stuff.. then have it remapped but i'm biased..
  9. Re: A4 Avant 2.5 TDi Quattro fuel economy
    May 2009
    Glasgow
    Interesting responses, I'll maybe try some forte through it...
    sr-performance, I've been wondering about re-mapping, but not sure how that helps with an auto 'box? Surely the auto box "program" remains unchanged, so the box doesn't know the engine's response has changed, so there's no benefit? Or am I missing something? I can see that with a manual car, you can easily change your gear change habits, but the auto is fixed...
  10. Re: A4 Avant 2.5 TDi Quattro fuel economy
    May 2009
    Hiya mate,
    when you remap, it physically alters your torque settings etc so you can make the engine respond better at low revs, so as it is now stronger at lower rpm you dont need to rev the engine as much due to the increased torque settings.. hope that sort of explains it a bit..
  1. a4 140 tdi multitronic bad fuel economy
    By ptflooring in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-03-2008, 07:50 PM
  2. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  3. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  4. Replies: 0
    Last Post: 05-03-2006, 07:58 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
