Thread: Oil Pressure. Stop Engine
Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 171
  1. Re: Oil Pressure. Stop Engine
    Sep 2008
    Bolton Lancs
    6 Post(s)
    Its off the car now so I cannot use vcds to check it
  2. Re: Oil Pressure. Stop Engine
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    More difficult to check without specialist equipment as essentially there are no visual differences between a full one and an empty one.
    See if there is anyone locally that cleans them - it's cheaper than replacement, legal and has covered enough miles to warrant a clean anyway. The Carbon Mass and Soot load figures would need to be reset when a new or cleaned unit is put back on using VCDS. There is an adaptation option in the Adaptation menu of the Engine controller but this only does part of the reset. For a new unit reset the figures to zero (using 1 not 0 as it happens as using 0 defaults to something else oddly) but for a cleaned unit there may be a small amount of residual ash left so I would set the Carbon Mass to 1 or 2 grammes to start with.
    Mad Mitch
  3. Re: Oil Pressure. Stop Engine
    Sep 2008
    Bolton Lancs
    6 Post(s)
    Well the car is back on the road with repaired oil pump and recon turbo and 12 months mot now to do the timing belt and waterpump
  4. Re: Oil Pressure. Stop Engine
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by markspark71 View Post
    A breeze of a job after what you've just done!
    Mad Mitch
  5. Re: Oil Pressure. Stop Engine
    Sep 2008
    Bolton Lancs
    6 Post(s)
    All parts delivered today from Tps so a nice job for the weekend weather permitting
  6. Re: Oil Pressure. Stop Engine
    Jan 2012
    10 Post(s)
    88 Post(s)
    The tensioner is a quirky little thing - involves rotating, locking, rotating again then tightening when the pointer is in the right place
    Just make sure the tensioner stud is still tight and doesn't undo when you release the tensioner nut. If you replace the tensioner stud it is very important to install the new one correctly and to the exact torque. I stick Loctite on mine usually.
    Good luck.
    Mad Mitch
  7. Re: Oil Pressure. Stop Engine
    Sep 2008
    Bolton Lancs
    6 Post(s)
    All done now just the dsg servive to do in a couple of weeks
    Thanks for all your help
    0 2 0
  8. Re: Oil Pressure. Stop Engine
    Jun 2018
    Hi can anybody help I have a 2005 vw touran 1.9tdi oil pressure engine off warning has had new turbo, egr valve, full service, oil pump, been in with vw dealership plugged in on the computer, oil pressure test new oil filter and oil change still with same problem oil pressure engine off they can't find the course so far said they can do More tests but will probably run me into the thousands can any one recommend anything thanks in advance
  9. Re: Oil Pressure. Stop Engine
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by roundmanx View Post
    Faulty oil bypass valve in oil filter housing causing return of oil straight to sump perhaps? If your oil pressure sensor is not faulty - have they checked this? - then it would possibly read low pressure in the housing if the bypass valve is stuck open (I believe the oil pressure sensor is connected to the side of the oil filter housing, like it is on the 2.0 litre).
    Mad Mitch
  10. Re: Oil Pressure. Stop Engine
    Jun 2018
    They haven't checked oil bypass valve they want to replace the engine they think it will be cheaper then looking for the actual problem I wondered if the oil feed pipe would cause it I noticed it was twisted since turbo was changed but they say shouldn't be the cause as oil pressure engine off warning was on before turbo and oil pump was replaced
  1. 1997 A4 1.8T Sport - Power delivery and oil pressure
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2009, 06:22 PM
  2. oil pressure problem
    By silverado in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-04-2008, 05:05 PM
  3. Replies: 1
    Last Post: 25-03-2007, 11:03 PM
