Thread: High Oil Pressure
  1. High Oil Pressure
    May 2007
    I'm concerned that my S4 oil pressure is to high. At 1,000 rpm it is reading about 50psi but at 4,000 rpm it reaches 90psi. Is this normal? If not could anyone have any idea what could cause this?
    Thanks,
    Matthew
  2. Re: High Oil Pressure
    At higher engine speed the oil pressure must not exceed 7.0 bar. If necessary renew oil pump cover with pressure relief valve.
  3. Re: High Oil Pressure
    May 2008
    Newbury
    7 bar being just over 100PSI, this suggests you don't need to worry if you are at 90.
  1. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  2. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
  3. Answers From The Oil Expert
    Last Post: 22-10-2007, 08:28 AM
  4. Answers From The Oil Expert
    Last Post: 05-10-2007, 03:25 PM
