Thread: Mk 4 Golf GT Tdi esp & abs warning light problem
  1. Mk 4 Golf GT Tdi esp & abs warning light problem
    Jun 2009
    Edinburgh, Scotland
    Hello guys and girls, just registerd on here today beause I really need some help from yourselves if possible.
    The ESP and ABS warning lights on my Mk 4 Golf 130 gt tdi came on two days ago and won't go off. I have spoken to a couple of people who have suggested various problems with differing levels of solutions and prices. The one constant seems to be that it's best to get it on the diagnositics and have a look to see what the problem is.
    So far there appears to be no braking issues/grinding/shuddering, etc. What are the chances that this is a fairly straight forward sensor issue with a relatively cheap solution, or am i looking at the abs brain needing replaced (as told by someone) and having to max my credit card???
    Any help would be greatly appreciated.
  2. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Southern County Softy
    20 Post(s)
    A code read is the first thing to do.
    Get it done then post codes on here for help.
    Could just be a dirty or failed sensor.
    A4 2.5 tdi QS (mapped)
  3. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Jun 2009
    Edinburgh, Scotland
    Cheers kite.
    I assume I'll get the codes from a diagnositc test. Hopefully my mate will be able to get me a discounted check at a VW garage and then I can post the codes on here.
  4. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Aug 2008
    Wigan
    9 Post(s)
    I have exactly the same problem on a 1.9TdiSE PD100 - it's going in under warranty some time soon and if I find out anything I'll post the information.
  5. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Jun 2009
    Edinburgh, Scotland
    Cheers batteryman. Unfortunately my Golf is second hand and an 02 plate, so I'll be paying for it out of my own pocket.
  6. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Aug 2008
    Wigan
    9 Post(s)
    Mine's a 52 plate but I was lucky to find a low mileage VW approved car that I wanted so it's got the warranty. We'll see how it goes, hope yours is a simple inexpensive fault easily fixed.
  7. Re: Mk 4 Golf GT Tdi esp & abs warning light problem
    Aug 2008
    Wigan
    9 Post(s)
    Initial fault showing was both ABS and ESP warning lights showing on dash display. Repaired under warranty and turned out to be a faulty abs wheel sensor. I don't know the cost of the repair, mostly labour I guess at a main dealer. A fault code read should show what's wrong and if it's a sensor they're fairly easy to change.
  1. VW golf MK4 showing ABS light and warning sign
    By joecranejoe in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 19-08-2010, 10:21 PM
  2. Golf Mk5 GT TDI ABS Pump/Sensor
    By liviboy in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2009, 08:10 PM
  3. ABS Warning Light - A6
    By swgf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-11-2007, 10:08 AM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
