Thread: 1.8 TFSi Noisy at idle [Video]
Results 1 to 10 of 12
  1. 1.8 TFSi Noisy at idle [Video]
    Feb 2009
    I have noticed my 09 A4 1.8TFSi is a bit noisy at idle. The car only has 500 miles on it so far. Check my youtube vid and let me know if this sounds correct?
    http://www.youtube.com/watch?v=BOAr8boNzWU
    Jake.
    MY09 A4 Avant SE 1.8 TFSI 160 Manual - Meteor Gray - Phone Prep Low - AMI - Hill Hold Assist - Park Assist
  2. Re: 1.8 TFSi Noisy at idle [Video]
    Mar 2009
    Willerby, East Yorkshire....
    Hi...
    Sounds a bit like a diesel engine, But so did my Mk5 Golf GTI.
    Does it sound as bad from inside or is it only noticeable from the outside.
    There are plenty of threads about this on the golf GTI forum.
    http://www.golfgtiforum.co.uk
    Here's one... http://www.golfgtiforum.co.uk/index.php?topic=115268.0
    And another... http://www.golfgtiforum.co.uk/index.php?topic=88202.0
    Have you tried using 98RON petrol.
    Martin
    Gone... A4 S Line 2.0T Quattro S Tronic Plus Options. Here... A5 S Line Special Edition 2.0TDI Quattro Manual With HDD Tech Pack...
  3. Re: 1.8 TFSi Noisy at idle [Video]
    Feb 2009
    I cannot really hear it from the inside except for a slight ticking when radio etc is off and parked. I havent tried 98ron fuel yet as its only done 500 miles and still runinng in. Cannot see the point in paying for 98ron when I dont go above 3k rpm!!
  4. Re: 1.8 TFSi Noisy at idle [Video]
    Mar 2009
    Quote Originally Posted by Nano Jake View Post
    Have you been able to read the threads that I'd posted as I think you've HIT THE NAIL ON THE HEAD. The ticking you can hear is the fuel injectors firing.
    As for 98RON petrol, you can try it anytime you like. The TFSI engines run best on this stuff, But can also run on 95RON.
    Martin
  5. Re: 1.8 TFSi Noisy at idle [Video]
    Feb 2009
    Quote Originally Posted by 73kingstonroad View Post
    Martin
    Yes I did read through those threads. Does sound like the same issue, to me though it sounds more like a metallic knocking than injector ticking but then maybe I am just not used to this type of engine and a bit paranoid as its a new car developing new noises as it gets used more.
  6. Re: 1.8 TFSi Noisy at idle [Video]
    Bristol
    Im glad someone has posted this, because I couldnt be bothered and thought it was just me.
    I stood at the door of our house a few days ago as my Mrs started up my 1.8, adjusted the seat and drove off. It sounds like a bag of spanners........never heard before as im always inside the car!
    I have noticed that when it starts up it makes one noise and then 30 seconds later the tone changes and there is a rattle from the exhaust and some weird noises coming from under the drivers door, petrol pump I guess. Car drives fine and where possible always use Super Unleaded 99. Sounds like a diesel sometimes and I was suprised at the noise from such a new car
    Just watched your video and it sounds the same as mine
    Aruba Blue B8 S Line 1.8T 160bhp,Piano Black Inlays, Black Stitching, 30mm S Line Drop
  7. Re: 1.8 TFSi Noisy at idle [Video]
    Feb 2009
    Quote Originally Posted by mkc View Post
    Well at least it means we dont have a problem. How many miles has yours done? I wonder if it gets better as its run in...
  8. Re: 1.8 TFSi Noisy at idle [Video]
    Bristol
    just under 7000 now, delivered on the 1st September 08.
  9. Re: 1.8 TFSi Noisy at idle [Video]
    Feb 2009
    That blows my theory out of the water! Can you hear a ticking noise from inside? I can when on the drive with radio off.
  10. Re: 1.8 TFSi Noisy at idle [Video]
    Feb 2007
    Cosheston
    I ran a 3.2FSi Passat SEL 4Motion for 65K miles and that sounded like a diesel at Idle from the outside - but it was virtually silent inside and quietened down to nothing when you moved off (except for the V6 exhaust note - lurvely).
    I am waiting for a 2.0TFSi A4 Avant multitronic and I have read it is noisy too. I couldn't find one at a dealer to test, so taking a leap into the dark.
    [SIGPIC]Misano Red/ Lunar Silver A6 Sline Stronic on order - 520D Tourer now - A3 S-Line 2.0 TDi DSG - T5 130 4Motion Camper
  1. Realistic MPG for 1.8 TFSI and 2.0 TFSI?
    By jsgreen89 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2009, 12:13 PM
  2. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  3. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  4. A4 1.8 Not Quite Idle
    By pelops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-12-2007, 07:55 PM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
