Thread: Intercooler Hose/ Engine Tone
  1. Intercooler Hose/ Engine Tone
    Apr 2007
    Wirral
    Dear all
    I've just found this forum it looks great and a really useful resource
    I have owned 5 VW Diesels over 18 years e.g 2 Jetta MkII and 2 Passats (Hatchback)
    Currently I have a 2002 Passat Estate 130TDI owned since June 2005 with 150k on the clock with Full Dealer Service History.
    About 6 months ago it began to make a noise similar to a slight exhaust leak and then recently the large Intercooler hose burst and I lost power.
    My mechanic quickly found the problem and replaced the hose he also found a lot of gunge in the inlet manifold but no exhaust leak.
    He was however concerned about what might have caused the hose to burst in the first place but wasn't sure.
    I now have the car back and although it runs great it still has the unusual tone to the engine, although this may be unrelated I still feel it might have a baring on the hose failure.
    If anyone can comment I would be grateful
    Dec 2006
    Durham, England
    Hi Denny,
    Thought I would compile a list of things for the members in general. Here's some items that might be a useful point to start a process of elimination...
    Motor Noise: Muffler Explosions
    Possible Causes
    Mixture not exploding regularly
    Exhaust valve sticking
    Dirt under exhaust valve seat
    Sticking breaker points
    Ruptured muffler
    Motor Noise: Popping or Blowing in Carburetor
    Possible Causes
    Not enough gasoline (open needle valve)
    Spark retarded too much
    Weak battery
    Incorrectly timed inlet valves
    Inlet valve not seating
    Defective inlet valve spring
    Dirt under inlet valve seat
    Pitted contact points on timer
    Motor Noise: Hissing and Squeaking
    Possible Causes
    Poor lubrication (causes squeaking)
    Leaking or ruptured muffler
    Leaking around spark plug
    Leaking cylinder head packing
    Loose joint between motor and exhaust manifold
    Loose valve spring chamber cover
    Broken insulation on spark plug
    Broken piston rings (blowing sound)
    Tight piston rings (scraping sound)
    Dec 2006
    Maidstone, Kent.
    The above list does seem fairly comprehensive, but your noise may well be much simpler to trace.
    My 130 TDi developed a similar noise to that which you describe, after not too much hassle I traced it to a poorly fitting air intake hose onto the air filter body. I can only assume that with time, and numerous removals to change the air filter, that the retaining mechanism becomes weak, the end result being that no matter how many times you push it back into place, it 'rides up' in use, it only needs to move by about 1/2 inch max to give the induction noise, you can also see on mine where it has rubbed on the underside of the bonnet.
    I suppose I could splash out on a new hose, what I in fact did, was to fix a piece of foam on top of the offending hose, such that when to bonnet is shut it applies a light enough pressure to push the hose onto its correct mounting position.
  4. Intercooler Hose/ Engine Tone
    Apr 2007
    Wirral
    Hi Brogandb7 and Dave
    Thank you for the Fault List and possible solutions I'm sure some will apply to my engine although it's a diesel, I'll certainly check the exhuast.
    If there isn't already one on this website your list might be used as a basis for a more comprehensive stock faults and solutions list.
    and thanks Dave for the info relating to the new engine tone I will have a closer look at the air intake.
    Many Thanks to both of you for taking the time to reply
    Denny
  5. Re: Intercooler Hose/ Engine Tone
    Aug 2007
    although this is a very late response, it may help others out there. i spent many years working with agricultural turbo deisels (fendt and massey ferguson, to be specific) and and whenever an intercooler line ruptured it was from being saturated with engine oil ( incompatible lubricant for the hose material ).
    oil from a leaking turbo or issues with exhaust gas recirculation ( usually the problem with the fendts ) let oil into the intake system and would soften and swell the hoses until they burst.
    so, anyone with a turbo car and spongey hoses, look for a sloppy turbo bushing or plugged EGR system.
    dan
  6. Re: Intercooler Hose/ Engine Tone
    Apr 2007
    Wirral
    Thanks Dannyboy
    I have now sold the car but before doing so had found out that my mechanic had botched the intercooler hose replacement causing me so much trouble.
    I got some money back from him and had the hose replaced at another garage
    I gave all of the details to the purchaser
    Many Thanks once again
    Denny
  1. TDi Engine hose blows off at 3000rpm!
    By DaveJB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 12:47 AM
  2. Stone cold bottom rad hose...
    By colifeashots in forum Passat - Archive Topics
    Last Post: 24-02-2007, 04:16 PM
  3. Top rad hose - Golf Mk III VR6
    By gavin567 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-01-2007, 02:06 PM
  4. Turbocharger/Intercooler Hose Oil leak
    By Rich1 in forum Passat - Archive Topics
    Last Post: 10-10-2006, 10:37 PM
  5. I just broke the fuel hose connector
    By Moocow in forum Archive posts
    Last Post: 30-09-2006, 08:02 PM
