Thread: Audi A3 2.0 Cutting out problem
  1. Audi A3 2.0 Cutting out problem
    Jun 2009
    Edinburgh
    Hi i have an Audi A3 mk2 2004 2.0FSi. I have a problem where my car keeps losing all power and going to idle revs untill i stop and set off going again.
    It also enters limp home mode (where ECU stops car reving over 3000rpm to protect it). Now the car is struggling to start sometimes but runs seamlesly other times.
    I've run diagnostics and the following faults where identified:
    Misfire on cylinder 1
    Misfire on cylinder 2
    Misfire on cylinder 3
    Misfire on cylinder 4
    Random misfire
    Fuel pressure sensor - low pressure
    Any body got any ideas im getting desperate.
    Cheers, Kyle
  2. Re: Audi A3 2.0 Cutting out problem
    May 2009
    Essex
    Kyle, sorry to hear of your problem but have you tried googling your problem? If you type the following into google search there's a number of hits with owners having similar problems - the symptoms vary :
    audi "Misfire on cylinder 1"
    kkp
  3. Re: Audi A3 2.0 Cutting out problem
    2018 Post(s)
    In tank fuel lift pump, very common.
  4. Re: Audi A3 2.0 Cutting out problem
    Hi - I know this doesn't help you but, having read your post I can't help thinking how lucky you are.
    With so many clear fault codes you should have no trouble locating the cause of your problems.
    I wish my similar problems would show up so many clear fault codes!
    I might be able to wake up from my nightmare!
    Good luck, hope you get sorted soon.
    JP.
  5. Re: Audi A3 2.0 Cutting out problem
    Jun 2009
    Edinburgh
    Yes it has helped however its taken me a month of my car running like s**t to eventualy get any codes from it and now it wont start but at least now im on my way to getting it fixed.
    Ordered a new rear fuel pump from audi today cost £115 + VAT so hopefully fingers crossed that should solve my problem if not its onto the high pressure pump or fuel pressure sensor. Anyone any other ides just in case?
    Will post my progress.
    Cheers guys,
    Kyle
  6. Re: Audi A3 2.0 Cutting out problem
    I was thinking fuel pump. But I'm no mech so I didn't want to suggest it.
    I think your doing the right thing.
    JP.
  7. Re: Audi A3 2.0 Cutting out problem
    Jun 2009
    Edinburgh
    Pump arriving on thursday will let you know how it goes. Apparently its wuite an easy job as the pump is on top of the tank under the back seats.
    Cheers,
    kyle
  8. Re: Audi A3 2.0 Cutting out problem
    Jun 2009
    Edinburgh
    Rear fuel pump fitted solved the problem!!! Thanks for the help
  9. Re: Audi A3 2.0 Cutting out problem
    Pleased to hear the good news.
    Mines been running like a dream all week!
    Still going to an alternative maindealer tomorrow for various possiblities to be checked out.
    I'll post any interesting details.
    JP.
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. New audi s4 raises the benchmark for handling dynamics
  3. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
  5. New additions to A3 turbo range
    Last Post: 11-08-2005, 08:32 PM
