Thread: Speedo needle vibrates when ignition turned on
  1. Speedo needle vibrates when ignition turned on
    Jul 2008
    Great Wyrley, Staffordshire, UK
    When I turn on the ignition of my 1.8 20V GTI (AGN engine), the speedo needle vibrates. When I start the engine, the needle continues to vibrate and the tacho doesn't move. However, after about 5 seconds, all returns to normal, with the tacho showing the engine speed correctly and the speedo needle still.
    The speedo works perfectly when moving.
    When the engine is stopped, the speedo vibrates again for 5 seconds before remaining still.
    Any ideas?
  2. Re: Speedo needle vibrates when ignition turned on
    I would check all earth points under the bonnet,anything else odd happening with anything ellectric?
  3. Re: Speedo needle vibrates when ignition turned on
    Jul 2008
    No other electrical items seem to be doing strange things, and earth connections seem good.
    Seems strange that the fault only occurs for a short but precise time.
  4. Re: Speedo needle vibrates when ignition turned on
    Jul 2008
    I still get this problem. Am I the only one?
  1. Please help, Airbag message when ignition first turned on.
    By jon-t in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2009, 08:52 AM
  2. Speedo Calibration
    By Maj in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2008, 12:31 PM
  3. beep from dash when ignition is turned on
    By johno in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-05-2007, 06:45 PM
  4. Stereo ignition sense problem
    By andym82 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 11:50 AM
  5. vw golf 1988, no current from ignition coil?
    By Nelson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-12-2006, 10:50 AM
