Re: How to un-jam the coin storage tray –
31-05-2009,06:31 PM
Originally Posted by
n_c
Hi all.
I have managed to jam the coin tray closed (the one above the radio) by putting too much in it. Does anyone know how to get in to fix it please? I wondered if taking the radio out may enable me to reach inside and sort it out.
Any advice would be gratefully received!
Nigel
Had my coin tray out some time ago to change for an illuminated icon version.
Pull forward the capping strip that goes across the top of the centre console which is just above the coin tray/hazard switch/cup holder - it's only held in by friction and rubber mounts and is pulled out to the back of the car.
Then above the coin tray you should see too sprung plastic lugs - gently push these down and with a little persuasion your coin tray should slide out - you may have a wire connected to the back of it if your coin icon is illuminated - not all models have icon illumination. Normally this is easy as the coin tray slid out makes it easier to pull out!
The coin tray assembly is a self contained assembly that slides into the centre console cage - taking the radio out may give you additional leverage to push the tray forward with the two clips disengaged.
A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
