Thread: Passat Boot Lock doesn`t Lock
Results 1 to 10 of 10
  1. Question Passat Boot Lock doesn`t Lock
    Jan 2006
    Aberdeen
    Hi Folks, What a fantastic Forum ! I `ve had my `01 Passat TDI 130 since June and love it. However the boot lock doesn`t stay locked it stays closed thanks to the struts but unlocks itself at random. Although I have noticed it happens more when the lights or ignition are switched off.
    Thanks again for your help.
    Oct 2005
    Sounds as though you have a faulty boot microswitch. Unless you feel otherwise, the following is how to replace it - part number is (or was) 8D5 959 489
    Quote Originally Posted by An American forum member
    Take off the trunk liner with a Phillips head screwdriver or use a power drill if you have one. Take out all the felt covered screws (13 in all). The liner will hang from the grip handles sitting in their holes. Just lift up on the liner and it will come off.
    Now look at the mechanism and notice the rod going from the lever to the ball joint. Just bend the little white clip off the rod and slide it to the side. The rod will fall out of the hole and hang there by the ball joint. There is no need to remove the other side.
    Unscrew the 2 bolts that hold the locking mechanism and let it hang. You will see the 2 little notches that hold in the switch. Just lift up on the black cover and it will uncover the switch. You don't need to squeeze the notches.
    Be careful. *There are 2 washers under the black cover that may fall out* They go under the black plastic in between the metal and plastic where the bolts go in.
    Now tilt the switch up and pull it out.
    Getting the plug out is a matter of lifting one side while trying to lift the other. It was probably the hardest part and not too hard at that. I just lifted one side and held it while using my nail to pry up the other side. It's a touch and go process.
    Unhook the old switch and hook up the new one. Place switch back in the lock and cover the tabs with the black plastic *make sure the washers are there*
    Everything seems clean and functioning well, but if you feel like oiling something, now is the time to do it
    Now bolt in the lock and test everything.
    Put on the trunk liner and you're done
    Now my trunk light works (didn't before), my trunk open indicator works (didn't before) and it doesn't "meep" (did before) when the trunk is open because it thought it was shut.
    PROBLEM SOLVED
    There is another how-to here linkage
    Hope this helps
    Sam
  3. The Microswitch
    Jan 2006
    Aberdeen
    Thanks for the info I`ve printed it off, spoken to my main dealer and they have it in stock. This is a job for saturday night. Apparently according to our local VW man they do have a tendency to go wrong. Will let you know how I get on
  4. Thumbs up
    Oct 2005
    Good luck, I hear a beer makes the job go smoother
    Jan 2006
    Aberdeen
    Oh well its not the microswitch. I replaced the old one which was quite corroded at the connection but the problem still persists. I even disconnected it and the motor still moved. Any ideas? Thanks for your help so far tho.
    Oct 2005
    When you had the boot apart did you notice if there was still a return spring on the latch mechanism?
    Mine broke after the boot kept getting slammed (by people who have never had a German car!).
  1. Boot Lock Issue
    By mrecho in forum Passat - Archive Topics
    Last Post: 04-02-2008, 02:23 PM
  2. Boot Lock
    By lennymfo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2007, 12:07 PM
  3. Boot Won't Lock
    By new to vw in forum Passat - Archive Topics
    Last Post: 20-03-2007, 06:18 PM
  4. Passat Boot lock/latch problem
    By mattgt3 in forum Passat - Archive Topics
    Last Post: 28-02-2007, 04:25 PM
  5. 96 passat boot tailgate lock
    By dyson in forum Passat - Archive Topics
    Last Post: 01-01-2007, 11:34 PM
