Thread: mr ali
  1. mr ali
    Feb 2009
    I have a 98 polo 1.4cl which now doesn't want to start from cold.If i start it and let it try tick over for a minute it will go ok.If i start it and attempt to drive it straight away it cuts out .
    Could it be a problem with fuel lines? I have had a head gasket and thermostat replaced very recently any help is greatly appreciated
  2. Re: mr ali
    135 Post(s)
    2026 Post(s)
    I would suggest a fault code read but it will probably be a faulty coolant temperature sensor telling the ECU the wrong temperature so the mixture is too weak on start up, rather like not pulling out the choke on an old fashioned car.
  3. Re: mr ali
    Feb 2009
    Thanks Crasher, Is that located just underneath the distributer cap? Any idea of price of the part?
    Thanks again.
  4. Re: mr ali
    135 Post(s)
    2026 Post(s)
    Yes, about £25 genuine plus £1 for the O ring.
  5. Re: mr ali
    Feb 2009
    Thanks crasher the sensor sorted the problem you saved me a great deal of time.But for some reason the stat and back cap or stat housing gave up the ghost at the same time.Next on the to do list will be the brakes.Thanks again
  1. Answer A Question & Ask Any Question?
    Last Post: 23-11-2011, 01:51 PM
  2. Aircon Drain
    By Frank.A in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-04-2009, 11:21 AM
  3. A4 1.9 TDI Ali window trim replacement
    By jonsablue in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-03-2008, 01:47 PM
  4. 1z engine noise
    By eddiemax28 in forum 80 - 90
    Last Post: 27-01-2008, 02:14 PM
  5. Cancelling Engine Warning Light
    By Schwartz in forum Polo - Derby - Lupo - Fox
    Last Post: 04-01-2008, 08:42 AM
