Thread: Engine Idle adjustment 1.6 AZD
  1. Engine Idle adjustment 1.6 AZD
    Mar 2009
    Having basically had the local VW experts pour over the car at great expense to find the reason I had poor performance/cutting out - all to no avail - I have determined that a faulty coil pack was the cause. Having replaced this (a the other 3 for good look) I would say the engine is about 95% ok although it is a bit flat when at operating temp and pulling away from junctions but other than that it seems fine and fuel comsumption seems fair.
    The only obvious thing I can see is that the normal operting tick over revs are a circa 620 and I assume this may be due to the dealers resetting/tuning or whatever they think they did when the engine when it was effectively only performing on 3 cylinders!
    Do I need to get the car on to a full version of Vagcom to adjust the idle tick over revs to a more near normal value (circa 800 I guess) or will this adapt naturally over a 100 miles or so.
    I look forward to your advice.
  2. Re: Engine Idle adjustment 1.6 AZD
    135 Post(s)
    2036 Post(s)
    The throttle body needs removing, cleaning and resetting using suitable diagnostic equipment such as a registered version of VAG-COM/VCDS.
  1. Please Help 1.6 AKL idle problem
    By witblitz in forum Golf MK4 - 1999 - 2004
    Last Post: 03-04-2011, 04:46 PM
  2. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  3. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  4. Mk3 Golf 1.6 Petrol Idle Bunny Hop Stalling problem
    By Gaston in forum Golf MK3 - 1993 - 1999
    Last Post: 14-02-2007, 07:47 PM
