Thread: A3 2.0TFSI Quattro power problem
  1. A3 2.0TFSI Quattro power problem
    May 2007
    Hi Guy's,
    Newbie to the forum. Ive got an A3 2.0TFSI Quattro on a 2006 plate. I had a stage 2 remap about 4 month ago and over the past 6 weeks ive noticed that when the car is driven from cold to say work its fine. But if i return and then try to drive it before its cooled down, i have no power. It's as if the throttle is stuck and you have to really rev the engine to try and clear it. This keeps happening untill you let the car cool down.
    Ive changed the Piston Diverter Valve to a new OEM 2.0T Upgraded Piston Diverter Valve from Awsome GTI to no avale. Can anyone help?
  2. Re: A3 2.0TFSI Quattro power problem
    May 2007
    knee deep in clunge
    14 Post(s)
    look on the inlet manifold,there is a breather valve which has as small flap inside
    The flap dislodges and allows manifold pressure to leak into the rocker cover without a fault code
    Also disconnect the fuel pressuree sender and re try as these are problematic on the fsi engines
    scan for fault codes and post
  3. Re: A3 2.0TFSI Quattro power problem
    May 2007
    Many thanks a8 tech. Ill take a look in the morning and keep you posted
  1. Replies: 0
    Last Post: 30-01-2008, 08:33 PM
  2. Audi A3 1.8 8 T Fuel Trim DTC code & loss of power
    By aljrose in forum Audi A3 - Archive Topics
    Last Post: 13-01-2008, 09:47 AM
  3. Replies: 0
    Last Post: 17-05-2007, 08:08 PM
  4. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
  5. Unique look for Roomy New Audi A3 Sportback
    Last Post: 23-06-2004, 10:36 PM
