Thread: MPG Down, Performance Down :(
  1. MPG Down, Performance Down :(
    Mar 2008
    Hello Everyone,
    I recently had timing belt, water pump, head gasket and diesel filter done (£954) on my 115 gt tdi.
    Since this work my MPG has gone down (I used to get approx 55 mpg between Portsmouth and London, I now get approx 38 mpg) the performance has definitely changed too. It feels much more sluggish and I need much higher revs in gears 1-3 to get any positive response.
    Any ideas what might have casued this?
    Many Thanks
    JLS
  2. Re: MPG Down, Performance Down :(
    Feb 2009
    Middlesbrough
    any black smoke? or starting differences? they might have retarded the fuel pump a bit while fitting a new cambelt
    with out dissapointment you cant appreciate victory
  3. Re: MPG Down, Performance Down :(
    134 Post(s)
    2005 Post(s)
    The 115 is a PD. No separate pump.
    I would say they did the Tipex and pray method of cam timing which is completely inadequate, the crank and cam must be locked with blocking plate and pin respectiavley.
  1. Buying Oil, Some Basic Advice From Opie Oils
    By oilman in forum Chat - Anything with wheels
    Last Post: 13-10-2015, 11:16 AM
  2. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
