Hi guys got a 01 model 1.4 petrol bora with idling problems when hot she idles quite low @800 rpm and idles @1200 on cold start.On a code read the scanner reads:17748-163kwp1281,camshaft position sensor(G40),crank sensor incorrect(G28).P1340.
The engine also sounds harsh on idle,a bit like a diesel,do these engines have the clutch system on the alternator?Eng type is AXPThanks for your help
