Thread: Boot not popping open
  1. Smile Boot not popping open
    May 2009
    limerick
    Dec 2005 B6 Saloon, Boot not springing open properly but improves during warm weather.
    Failed totaly today, even though its warm, and required manual lift open (heavy)
    Both gas struts had failed, one dripping some fluid, €30 from local scrappie.
    40k miles but large amount of use of boot/opening & closing per mile!
  2. Re: Boot not popping open
    May 2009
    limerick
    Correction;
    only one of the two had actaully failed/dripping damper fluid.
    To install these gas assited struts requires it to be compressed slightly, however this requires huge force. VW have deliberately included a notch on the mounting bracket so as one can engage a special tool which levers against the strut to compress it before it pops onto its mount. Using a scredriver in the slot and a 12mm hollowed out piece of wood to stop screwdriver slipping of the struts conical end achives the same result.
  3. Re: Boot not popping open
    May 2008
    You're not alone, follow the previous link.
    https://www.vwaudiforum.co.uk/forum/s...highlight=boot
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. roof (assoc) problems
    By daver in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-10-2010, 08:14 PM
  3. Central door locking problem! Boot wont open! Please help!!!
    By MiniMadTez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2007, 10:19 PM
  4. Boot / Tailgate Central Locking Does Not Work.
    By Studio54 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2007, 12:16 AM
  5. Golf hatchback boot won't open - disabled driver.
    By Boozyuzi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-02-2007, 10:18 PM
