Thread: Wishbone bushes help!!
  1. Wishbone bushes help!!
    Sep 2008
    Kildare,Ireland
    Guys hows all?.Im lookin to get my hands on a pair of wishbone bushes.Anyone direct me?Mk 4 1.6 99...Thanks...
  2. Re: Wishbone bushes help!!
    Mar 2007
    U-96
    G07,
    The Lower Control arm (LCA/wishbone) uses two wishbone bushes;
    • Front bush
    • Rear bush
    Of these, the rear bush is usually more likely to be worn and so require replacment.
    The Front wishbone bush is VW part number: 357.407.182
    There are various replacement alternatives for the rear bush (VW part numbers following), in order of increasing stiffness these are;
    • Original voided rear bush: 1J0.407.181
    • Audi TT non voided rear bush: 8N0.407.181.B
    • Powerflex rear bush: PFF85-410
    While the original/voided bush has better ride comfort, it provides less steering response compared to the Audi TT rear bush, which should also be more durable due to the abscence of voids/gaps in the bush rubber compound.
    The Powerflex rear bush, is even stiffer than both the above.
    Original voided rear bushes can be sourced from;
    • VW/Audi/Skoda/Seat dealers
    • ECP
    • GSF
    Whereas the Audi TT bushes are supplied from VW/Audi/Skoda/Seat dealers.
    If you are looking for a straight replacement for existing LCA rear bushes, I would recommend purchasing the original/voided bushes. Lemforder (OEM quality) voided front LCA bushes are approximately £6/bush from ECP.
    Either quote the VW part number (mentioned above) or your car registration when ordering.
    Regards,
    TR7
  3. Re: Wishbone bushes help!!
    135 Post(s)
    2027 Post(s)
    If you want to make your life easier, fit a pair of new wishbones (those by Febi are very high quality) as they come with a pair of new bushes installed so you don’t have to press the old ones out and new ones in which is awkward without a press. You could also consider fitting Powerflex
    http://cgi.ebay.co.uk/Golf-4-Powerflex-Polyurethane-Wishbone-Bushes-201-410_W0QQitemZ110355496894QQcmdZViewItemQQptZUK_Car sParts_Vehicles_CarParts_SM?hash=item19b1b33fbe&_t rksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C 65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1% 7C294%3A50
  1. Replies: 3
    Last Post: 28-05-2009, 11:17 PM
  2. Golf MKIV Rear Axle Bushes
    By Stanhope in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2008, 08:08 AM
  3. Polo wishbone rear bushes
    By sbhammo in forum Polo - Derby - Lupo - Fox
    Last Post: 07-04-2008, 09:17 PM
  4. Audi 80 TDi Wishbone bushes
    By andypdq in forum 80 - 90
    Last Post: 01-07-2007, 09:01 AM
  5. Audi 90 2.3e wishbone bush renewal
    By m4xmw in forum 80 - 90
    Last Post: 24-05-2007, 08:08 PM
