Thread: Fault cold 00575
  1. Fault cold 00575
    Jan 2009
    Lancashire
    Hi all
    Can anyone please tell me if they have come a cross this fault code 00575 (Intake Manifold Pressure)
    My car is A4 2.5 tdi 180 Quattro 2001.
    This morning I was accelerating hard, when I’d changed to the next gear there was no power for about 2 seconds then all was back to normal.
    When I got home I immediately plugged in my VAG 5053 and it came up with this code.
    This isn’t the first time my car has done this, that’s why bought the VAG.
    Can anyone point me in the right direction in how to fix this problem?
    Many thanks
    Taz
  2. Re: Fault cold 00575
    Southern County Softy
    20 Post(s)
    Taken from the Ross tech wiki
    00575 - Intake Manifold Pressure: Control Limit Not Reached
    Possible Symptoms
    Sudden complete loss of Power
    Reduced Power
    Possible Causes
    Hoses incorrect connected, disconnected, blocked or leaking
    Pressure Unit for Turbo Charger defective
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses
    Check Pressure Unit for Turbo Charger
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check Basic Setting > MVB 011
    00575 - Intake Manifold Pressure: Control Limit Exceeded
    Possible Symptoms
    Reduced Power
    Charge Pressure too High
    Possible Causes
    Possible Solutions
    00575 - Intake Manifold Pressure: Control Difference
    Possible Symptoms
    Reduced Power
    Possible Causes
    Possible Solutions
    Check Hoses
    A4 2.5 tdi QS (mapped)
  3. Re: Fault cold 00575
    134 Post(s)
    2020 Post(s)
    The vane ring and vanes inside the turbo are clogged or faulty and the turbo needs cleaning or replacing but before removal the actuating system needs checking which is done in Basic Settings 04, Main group 011, IF your copy of VAG-COM is registered.
  4. Re: Fault cold 00575
    Jan 2009
    Lancashire
    Thanks for the advice guys.
    I’ve just check the intercooler hoses and done the test on the actuating system and everything seems to be working fine, so its looking like the turbo needs cleaning or replacing.
    There is a company need me call turbo force that do HYBRID conversions so I shall be taking a trip there this week.
    Just what I needed as iam planning to go down south 1st week in June. Ha!
    Thanks again for the help, and I will let you know how I get on.
    Taz
  1. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  2. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  3. 2006 A6 Battery issues
    By wmccann in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2009, 04:08 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. mk4 tdi missing, cold start,ecu fault
    By dyl_55 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2007, 03:26 PM
