Thread: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
    Mar 2008
    Old Wessex
    Scotty - thanks for the info
    The thread over at tdiclub.com is something I've read through before. It's quite interesting but it seems whatever oil I've used in my gearbox I still get poor shifting in anything but warm (20 deg C +) weather. I'm almost 100% certain that the VW dealer would have used the correct spec oil when they rebuilt the gearbox.
    It's one of two things:
    1. My gearbox, or something that serves in an ancillary capacity (clutch, flywheel, linkage, etc.), is broke. Exactly what it is though.... not a clue! Although, I do know that my synchros should be in top working order as they were replaced 1k ago by VW.
    2. It's a quirk of the manual 6-speed box, as reported from many VAG sources.
    Either way, I need to either find the underlying problem and get it fixed, or if there is nothing found, just live with it....
    The thing I'm most concerned about is long-term damage and longevity.
  2. Re: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
    I have the 6 speed in my bora, I know they arent the same but mine is abit crunchy first to second until warmed up too. Recent oil change helped alot.
    Another thing you might want to try is resetting the linkage, or getting it inspected to see of the joints are worn. Not hard to reset yourself, ill try and find a guide for it.
  3. Re: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
    Gwent
    Quote Originally Posted by the surfer View Post
    Also I read (unsure of credibility of source) that the A1/2 refers to whether the oil is synthetic or mineral; where A1 is synth and A2 is min.
    I'm fairly sure A1/A2 refers to the quantity in the bottle i.e 0.5 or 1 litre. seems unlikely a mineral oil would meet the same spec as a synthetic?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
    Quote Originally Posted by passat938 View Post
    Evening,
    I'm going to try and find a large speaker magnet to see how much sheered metal is in it
    Been for a drive out tonight and theres definetely an improvement.
    Dropping into 2nd gear is now smooth and positive (if I do it very fast there is a slight notchy feeling, but nothing like before where it sounded like I was chipping gear syncros on long grinds no matter how slow I shifted)
    2nd to 3rd works everytime and a minimal knock.
    4th to 3rd so far has worked everytime
    VW don't state the viscosity of their new G052, but it seems very thin, my shifts used to be worse when cold and when the oil warmed up and thinned became better. This new stuff is thin from the outset so could that be the solution?
    Either way a new gear box is £2000, a refurb £500, or a rebuild £600. A refurb doesn't even gaurentee other syncro's/gears won't play up.
    So for less than £100 it seems a good mod.
    any idea of the mileage when the gearbox started to play up ?
  5. Re: G052 911 A2 / 3H gearbox oil 170,000 mile change to fix crunch
    Gwent
    Evening,
    VW no longer quote the spec of their oils, I'm under the impression they are supplied by Fuchs lubricants.
    to summarise, 01 series transmissions use 75w - 80 grade and 02 series transmissions use 75w grade. The sintofluid gear oils meet the spec of the various VW part numbers for each type of transmission.
    Fuch's Titan Sintofluid 75w-80 which is equivalent to VAG
    G 052 171 A1/A2 A1 A2 being 0.5 litre or 1 litre I think.
    G 052 911 A1/A2
    Vagcat says I should be using
    G 052 911 A2 suitable for Passat type 01 series transmissions
    Sintofluid 75w meets
    G 052 512
    G 052 178
    G 055 726 Suitable for golf type 02 series transmissions
    Seems it also suits applications where G070 726 is called for:
    http://www.fuchs-europe.de/gear-oils-cars.html
    Both Sintofluids are Fully Synthetic Oils
    From the Horses Mouth
    http://www.opieoils.co.uk/pdfs/FUCHS...D%2075W-80.pdf
    http://www.opieoils.co.uk/pdfs/FUCHS...20FE%2075W.pdf
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. Gearboxes and Oil / Rust on MK3
    By redville in forum Golf MK3 - 1993 - 1999
    Last Post: 07-05-2008, 09:22 AM
  3. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:28 AM
