Thread: poor starting from cold
  1. poor starting from cold
    May 2009
    clitheroe, england
    Hi all, im new to the forum. I recently bought a 53reg gt tdi 150. all was good at first but its now developed a fault.first thing in the morning it takes 3 or 4 attempts to start with plenty of cranking.but when i leave work in the afternoon and the weather is hot It fires up on the button. the car turns over and i hear the pump kick in. could it be sub standard glow plugs? i removed them and checked them over.they appear new but are lucas which i understand to be a poor replacement part. or is it more likely to be the glow plug leads? or the engine temp sensor? someone else mentioned the 109 relay?
    PLEASE HELP!!!!!!!
    Ryan
    Hey up guys.had loads of trouble getting glow plugs for the car. vw dealer was saying use 30mm plugs, another dealer said use 27mm. andrew pages said use 30mm and finally another dealer said use either!!! settled on 30mm bosch plugs as the ones in the car were 27mm lucas ones. i dont think they are reknowned for glow plugs and bosch being a german company probably supplied the original ones?!?! hopefully this will solve the problem. if not then its back to the drawing board. will probably replace the engine temp sensor although ive had it on diagnostics and that only brought up "glowplug cyl 3 circuit" and nothing ese.
  2. Re: poor starting from cold
    Apr 2009
    Manchester
    Had a similar problem with mine just recently... turned out to be the automatic choke was clogged with carbon. Try giving it a clean.... worth a shot to rule it out and pretty easy/cheap to do!
  3. Re: poor starting from cold
    meathead Guest
    I've had starting issues, resolved by replacing the fuel filter (£7 from a dealer).
    PS - Do diesels have chokes?!
  4. Re: poor starting from cold
    Apr 2009
    Manchester
    Quote Originally Posted by meathead View Post
    I had a friend say the exact same thing to me this afternoon.... beginning to think the garage has fed me a load of bullsh*t, as they were having problems diagnosing/fixing the problem!
  5. Re: poor starting from cold
    meathead Guest
    Diesels can have a cold start mechanism, which they might be referring to. A "choke" is only on carburated engines. Fuel injection engines do not have chokes, but can advance the ignition to ease starting, which is a form of a choke I suppose.
  1. V5 cold start problem
    By V5_170Mk4driver in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 09:45 AM
  2. HELP! Polo won't start from cold!
    By mattijw in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2008, 09:51 PM
  3. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  4. Audi 80 2.0 SPI cold start issues?
    By panther12 in forum 80 - 90
    Last Post: 13-08-2007, 12:57 PM
