Thread: Starting Problems on Alhambra
  1. Starting Problems on Alhambra
    farquarpigmix Guest
    Hi All, I am hoping for some needed help & advice please.
    There are times when the car will turn over but not fire. I have had two diagnostics checks which showed up no fault. I changed the battery which I know was nothing to do with it.
    Last time it happened was yesterday and every time I have to wait for around 5 minutes plus to start it fingers crossed. I had to stop using a certain petrol station because every time I filled up it wouldn't start. The other one I use does it now & then.
    I hope & pray someone on here can help me.
    Regards
    Farquar
  2. Re: Starting Problems on Alhambra
    farquarpigmix Guest
    Update on above,
    At long last the problem has been solved. The fault is a ignition relay, known as relay 109. AA man said was a common fault and the relay was superceeded around 2003.
    My alhambra is a X 2000. The relays were fitted not just on alhambra but almost all VW diesel vehicles. This relay is black.
    If glow plug light didn't come on dash, car wouldn't start.
    I hope this Information helps anyone.
    Regards
    Farquarpigmix
  3. Re: Starting Problems on Alhambra
    Jun 2010
    bedfordshire, uk
    Excellent! I have found someone with (or had) the exact same problem I am having. My (X reg Alhambra) car is doing exactly the same thing. sometimes I have to leave it for a hour at a time before some how it resets itself. My wife is having our child in two days so I need it sorted. Initially I heard it was relay 95, the 98. But I looked on the internet and it looks like they have nothing to do with the ignition. So... its relay 109? Thank you thank you thank you! I will change this and let you know how I go!
  1. Seat Alhambra 1.9TDI Starting Problems
    By atul in forum Alhambra
    Last Post: 27-07-2010, 05:59 PM
  2. 2000 model Polo starting problems
    By Mr S.A. in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 01:42 PM
  3. Replies: 22
    Last Post: 08-03-2008, 08:16 PM
  4. Starting Problems
    By blergo in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 07:00 PM
  5. Replies: 0
    Last Post: 15-12-2007, 04:37 PM
