Thread: 1.8 20V APT gear selection issues
Results 1 to 10 of 15
  1. Angry 1.8 20V APT gear selection issues
    Dec 2008
    East Preston, West Sussex
    Hi all,
    I hope that someone can help me before I pay a lot of money for something that I may not require!
    My car is a 1999 1.8 20v B5.5 with the APT engine and DWH 5s gearbox, 71000 miles.
    I am experiencing quite a lot of trouble engaging 1st and reverse gear, sometimes to the point of turning the engine off in order to get the gear in. If I can get the gear in without resorting to this procedure, it is very hard to engage, and you can feel it grating and then it will push past and engage.
    I normally have to make sure that I engage 1st gear before coming completely to a halt. The it will engage cleanly.
    I also have some clunkiness in going from 1st> 2nd at times, and also a notchiness into 3rd on occasions.
    The gear oil was changed a few months ago but that hasn't made much difference. Also some Moylslip gear oil additive was also introduced but no difference.
    As far as I am aware the clutch is the original.
    Clutch slave cylinder was replaced a few months ago.
    Has anyone experienced anything similar or has any suggestions. All are welcome before I go and source a replacement gearbox!
    TIA,
    John
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  2. Re: 1.8 20V APT gear selection issues
    May 2009
    waterlooville
    I'am experiancing the very same issues..I was looking for the answer on here when i saw yours (LOL)
  3. Re: 1.8 20V APT gear selection issues
    131 Post(s)
    1976 Post(s)
    Do the gears select OK with the engine not running and the clutch depressed?
  4. Re: 1.8 20V APT gear selection issues
    May 2009
    waterlooville
    Yes when the engine is off mine selects fine..Mine only has the issues stated above in 1st and reverse?? very strange
  5. Re: 1.8 20V APT gear selection issues
    131 Post(s)
    1976 Post(s)
    More than likely a clutch issue then, the plate is not clearing the flywheel so dragging and still transferring a little torque which makes the gears difficult to engage.
  6. Re: 1.8 20V APT gear selection issues
    May 2009
    waterlooville
    I thought the same but the clutch isnt high or low which i would of thought would also of been the case??
  7. Re: 1.8 20V APT gear selection issues
    Dec 2008
    Mine engages fine when the engine is off, but can have issues when the engine is turning. Sometimes this happens sometimes it doesn't. When it does you can almost be locked out of 1st or reverse.
    Problem with these cars like a lot of others is that when you change the clutch you will really have to do the dual mass flywheel also as they muck about and fail. There is a clutch/flywheel kit available from ECP for this engine/gearbox combo. I guess that if the box is coming out for the clutch plate, for about 10mins more labour you can change the flywheel at the same time, saving time later on, but with a bigger bill initially.
    A new DMFW is around £300-£450 depending on source, and add to that the cost of the clutch pressure plate, around £130-£180...+ labour to remove the box, old clutch, and refit all back again...! Ouch.
    I am replacing the gearbox mounts to see if that helps as they will also be getting tired, then move onwards and do the clutch. Question also is, is the box knackered, cos if it is I might as well change that at the same time as I remove the old one!
    John
  8. Re: 1.8 20V APT gear selection issues
    Dec 2008
    With the hydraulic clutch, the bite point should stay the same, not change as the clutch wears.
    John
  9. Re: 1.8 20V APT gear selection issues
    131 Post(s)
    1976 Post(s)
    To a certain extent yes but the depth of the bite changes, difficult to put into words but you probably get what I mean.
  10. Re: 1.8 20V APT gear selection issues
    Dec 2008
    Well it's going in on Thursday for the DMF + Clutch to be changed, and am doing the gearbox mounts at the same time, as they may well be a bit tired also. Will let you know how it feels afterwards.
    John
  1. Hard gear selection
    By brybrybry in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:01 PM
  2. 2000 A4 1.8 20v (non turbo) performance and economy issues
    By manojluhar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2007, 06:11 PM
  3. 1998 A4 1.8 20v sticking in 2nd gear
    By andyc78 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-11-2007, 05:36 AM
  4. coolant temp sensor in APT 1.8 20v
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2007, 02:23 PM
