Thread: A4 Quattro Sport Rear Wheels Making Strange Noise
Results 1 to 10 of 40
  1. A4 Quattro Sport Rear Wheels Making Strange Noise
    May 2009
    Harrogate
    When I pull off at low speeds I get a strange noise coming from the rear wheels. Its the same kind of thing as if I were driving over the lines on the road approaching a round a bout or over cats eyes. It only happens at low speeds. I have a 2003 '52' plate A4 1.8T Quattro Sport. Can anyone help?
  2. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    Aug 2007
    Hi Adam,
    This might relate to your problem:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=67781
  3. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    Mar 2007
    Oxfordshire
    That's exactly what mine does! Are you sure it's the rear? I'm pretty sure it's the front on mine but it's possible I'm wrong... It must relate to the wheels - ie from the driveshaft onwards so it can't be the transmission or anything. I don't surpose your car does a funny jumping sideways in the wet thing when on hard lock?
  4. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    May 2009
    Harrogate
    It is defo coming from the rear and seems to be a bit worse if there is a lot of weight in the car. We went camping recently and there were 3 people in the back and all the equipment in the boot (quite suprised how much you could get in the boot!) I hope it is not anything too serious. At first I thought it may be the wheels rubbing as it has 18" RS4 alloys on it but I dont think this is the case. I have not had the problem in the wet though. It also does something similar if you are doing say about 70 on the motorway in 5th gear and put the accelerator hard to the floor.
    I am hoping it is not anything to do with the 4 wheel drive system?
  5. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    Mar 2007
    Oxfordshire
    While I was driving it today I was trying to pin down the circumstances which cause it but it's not easy. This is how far I have got;
    1. Happens when pulling off under load - ie up a hill or with weight in the car but not so much when you floor it.
    2. The knocks seem to coincide with the revolution of the wheels.
    So not much information but it suggests to me that it's not the transmittion otherwise the knocks would be far more regular...relating to the revs. I'm not an expert on 4WD but I did wonder about the diff between the front and rear axles - can these develop play???? If so would it cause a knocking like this? My car is an 05 with 60K miles and 6 spd btw.
  6. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    May 2009
    Harrogate
    Ok, this does sound like the same problem I think. Mine is defo coming from the back and only when setting off in a straight line at slow speed. Mine is a 2003 which has covered 67k miles and is only 5 speed (I do miss that extra 6th gear!)
  7. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    Mar 2007
    Oxfordshire
  8. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    May 2009
    Harrogate
    Dont like the sound of those!! I think we are looking a bit more into than we should be though. After reading those they report a clanging noise and stuff which isnt the case with mine! I am going to go out into the car park at work and try my car now just to see what happens. I will report back shortly!
  9. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    Mar 2007
    Oxfordshire
    Actually the engine mount adjustment has cured the problem by 95%. It still does it a bit when pulling off up a hill but not as bad. This is just after one 30 minute journey mind you but it's my regular journey home. Are you sure it's rear?
  10. Re: A4 Quattro Sport Rear Wheels Making Strange Noise
    May 2009
    Harrogate
    OK I give up. I cant for the life of me get it to make the noise!! I wonder if it was because it was stood for a couple of months before I bought it?
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
