Thread: 2005 A4S 1.9tdi S Line - INTERMITTENT REAR PARKING SENSORS
  1. Question 2005 A4S 1.9tdi S Line - INTERMITTENT REAR PARKING SENSORS
    Apr 2009
    HI, can anyone help please? Occasionally the usual tone when selecting reverse is replaced with a longer one, which I understand is indicative of a fault with the RP System but the problem is very intermittent {avg once every two weeks} which seems to suggest that there is a bad connection somewhere rather than a component failure. I would like to check the connections to the sensors but access seems to be almost impossible unless the rear bumper is removed, which I don't want to get into unless absolutely necessary. Can anyone advise whether this will be necessary and if not how to access the sensors? Also I would appreciate opinions on whether my hunch that this is a connection issue is likely to be right or just wishful thinking. Finally I realise that VAGCOM would help but I don't have access without visiting the local dealer,which tends to be very expensive.. Many thanks.
  2. Re: 2005 A4S 1.9tdi S Line - INTERMITTENT REAR PARKING SENSORS
    selford1 Guest
    I have a similar fault ith my rps but it has now turned into a continuos beep. Plugged in my viacom and fault code is poor earth, connection.
    Only way is to trace wiring & chk connections for corrosion or loos wire.
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  3. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  4. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
