Thread: 2.5 TDi 99 Oil leak??
  1. Question 2.5 TDi 99 Oil leak??
    Apr 2009
    I have an annoying oil leak on my A6. It appears to be coming from the rear of the engine, I have removed the bottom cover to aid my search. Since doing this this the 'tell tale' drops on the floor are in line with the four holes in the bottom cross member. Which leads me to the leak being somewhere above this, but I cant see anything. Looking on to top with the cover removed everything looks okay. I had a look on here and a few people appear to have had problems with breather pipes, could this be my problem? If so does anyone have a picture of where they are located? All comments welcome!!
  2. Re: 2.5 TDi 99 Oil leak??
    Engine code would help. It is on the service book or the label in the spare wheel bay. However your most common source of a leak, assuming the leak is oil not deisel, is the cam covers either the gasket or an injector to cam seal or the sump or the exhauster pump to head gasget at the rear of the forght head. Regards Peter
  3. Re: 2.5 TDi 99 Oil leak??
    Apr 2009
    Its an AFB engine, with a DEQ gearbox if it makes any difference.
  4. Re: 2.5 TDi 99 Oil leak??
    Dec 2006
    Crook, County Durham
    Hi Shaka1976, Check that the "O"ring on the crankshaft timing plug hasn't perished, 10mm ring -key. It's just above the crossmember.
  5. Re: 2.5 TDi 99 Oil leak??
    Dec 2008
    Ely, Cambs
    Also worth checking the turbo oil return o ring in the head. Difficult to see but if there's oil around the bottom of the pipe it could be...... I found easiest way to replace is to remove turbo, only takes a coulpe of hours, one awkward bolt holding turbo to manifold. o ring part no is 035115427 £1.19, or it's a 15mmX2.5mm o ring
  6. Re: 2.5 TDi 99 Oil leak??
    Dec 2008
    Ely, Cambs
    Another thing regarding oil breather. Remove oil filler with engine running, is there a lot of pressure? If so replacing the breather will help reduce the leak.
    Been there done that!!!!!
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. Oil Level 2.5 TDi
    By Bobcat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2008, 10:11 PM
  3. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 05-10-2007, 03:25 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
  5. vegetable oil for tdi?
    By aaron in forum Chat - Completely Off Topic
    Last Post: 16-10-2005, 05:10 PM
