Thread: 2006 3.0 TDI Quattro S-Line B7
  1. 2006 3.0 TDI Quattro S-Line B7
    May 2009
    Ards, N. Ireland
    I have a dry bearing noise coming from the front top of engine. I can see some sort of pulley behind a black plastic cover where the noise is originating from. Does anyone know what this could be?
  2. Re: 2006 3.0 TDI Quattro S-Line B7
    Nov 2008
    Sounds like the tensioner / deflection roller for the belt that drives the high pressure fuel pump that sits in the middle of the engines 'V'.
    Thats fairly accessible, so if you do have a dry bearing, it not a huge job to do.
    Just make sure its definitely coming from top end, as there is 2 or 3 rollers that control the auxilleries belt. They are located fairly well down on the engine at the front. Noises can 'travel'.
    None of these rollers are prone to early failure, so I am just covering all bases.
  1. Replies: 65
    Last Post: 22-02-2012, 02:12 AM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. AUDI S6 QUATTRO RELEASED FOR UK ORDERING
    Last Post: 14-03-2006, 09:10 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
  5. New Sporting Audi A6 S Line models arrive in britain
    Last Post: 15-07-2004, 09:40 PM
