Thread: 2001Beatle Cooling Problem
  1. 2001Beatle Cooling Problem
    May 2009
    Menifee, California, USA
    I have a 2001 Beatle with a 2.0 The Red overheat light comes on and stars flashing. I replaced the Thermostat with no change. The previous owner did not maintain well so with the car being 9 years old I replaced the Radiator and flushed the rusty water out of the system. But I still have the same problem. No coolant is leaking out. It does not seem to be a head gasket but you never know. Is their a special way to get the air out of the system I am missing? Is their an issue with the cooling system on this engine I need to check?
    Update: Found the problem. The wounderful Plastic impeller came apart on the Water Pump. I am in the process of changing the water pump and timming belt now. A plastic impeller is stupid to put on any car. I expect to see garbage like this on a Ford not a VW.
  2. Re: 2001Beatle Cooling Problem
    May 2009
    Just finished that solved theproblem.
  1. Mark 4 Golf Starting problem.
    By Oztrexx in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 01:08 AM
  2. 2001 golf gt tdi cooling fan problem
    By rallycraig in forum Archive posts
    Last Post: 09-02-2008, 01:27 PM
  3. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  4. A6 Cooling Problem
    By trainspotter in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-02-2007, 08:55 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
