Thread: A6 avant 2.0 TDI lumpy running.
  1. A6 avant 2.0 TDI lumpy running.
    May 2008
    Hi All,
    i have a 2007 2.0 tdi multitronic with 5000 miles on the clock.
    For 99% of the time it is a delight to drive,but very occasionaly when in traffic at say 10-15 mph and also when slowing to a standstill the running becomes very erratic /jerky,almost like the engine cannot quite decide what it should be doing.When this occures when stationary the idle is also erratic fluctuating between approx 800-1100 revs.
    I think that i may have read somewhere on this forum regarding a software update ,but i am not sure what specific problem this reffered to.
    The car has been into the dealers twice in the past for this problem ,each time with no fault found.
    Any thoughts would be appriciated.Thanks.
  2. Re: A6 avant 2.0 TDI lumpy running.
    May 2007
    knee deep in clunge
    14 Post(s)
    This problem is caused by insufficient torque and excessive egr,depending on your engine ecu software version it may be within the criterion for the sw update referring to this issue.If possible post the engine ecu details and engine code and i may be able to determine if there are any relevant sw solutions.You can only give the information i require with a diagnostic print out from the dealer or a vag com scan
  3. Re: A6 avant 2.0 TDI lumpy running.
    May 2008
    Thanks A8 tech for your reply.The car is going into the dealers on wednesday so if they can find no problem i guess if i ask for a printout they should give me a copy,shouldent they?
  4. Re: A6 avant 2.0 TDI lumpy running.
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes just ask the service receptionist for a diagnostic print out,i would hope the dealer finds any relevant sw updates or finds a fault.Regards A8
  5. Re: A6 avant 2.0 TDI lumpy running.
    May 2008
    Thank you,we"ll wait and see.
  6. Re: A6 avant 2.0 TDI lumpy running.
    May 2008
    Hi all,an update for you.
    car was in dealers for two days ,have loaded a software update so it is a case of try it and see
  7. Re: A6 avant 2.0 TDI lumpy running.
    May 2007
    knee deep in clunge
    14 Post(s)
    i am sure it will be fine
  1. 2005 A6 Avant 2.0 tdi Buying Advice
    By sturgi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-03-2009, 07:29 PM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
  4. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
