Thread: Start / Stop Info...
  1. Start / Stop Info...
    Mar 2009
    Willerby, East Yorkshire....
    Hi...
    Some Start / Stop info found on another site.
    Audi will introduce an onboard computer system fitted with something called the efficiency program as well as the familiar start-stop system. These technologies are part of the solutions that Audi will use to cut down fuel consumption levels by 20% on 2007 levels by the year 2012.
    Additionally the energy recovery system is installed. It is already available as standard specification in a number of Audi models. What it does is to feed energy back into the vehicle's electrical system during deceleration in order to further improve efficiency.
    The start-stop system works by shutting down the engine when the car comes to a halt. As the driver pushes the clutch the engine starts again. The system can be switched off manually at any time by pressing a button. Audi estimates that in the regular Euro cycle fuel consumption is lowered by 0.2 litres per 100km. C02 emissions are consequently reduced by 5 g/km. Cars that will receive the system first are the manual versions of the A3 1.4 TFSI, the A4 and A5 with 2.0-litre engines.
    The onboard computer with the efficiency programme comes with consumption-related data that is shown on the centre display. Drivers are then given recommendations for more efficient driving, depending on their style and the prevailing road situation. There is even a gearshift indicator to prompt drivers to change gears at the most ideal gear times. Also, systems that require extra energy to operate, like the air conditioning and seat warmers, are identified by the efficiency programme.
    Martin
    Gone... A4 S Line 2.0T Quattro S Tronic Plus Options. Here... A5 S Line Special Edition 2.0TDI Quattro Manual With HDD Tech Pack...
  2. Re: Start / Stop Info...
    Jan 2009
    Essex
    Thanks for the info!
    "The system can be switched off manually at any time by pressing a button."
    That's a relief! I've never used it but I did have a small concern that if I don't like it then I'm stuck with it.
    The real thing I was to know if does it apply the handbrake when the engine stops. This may help me be less disappointed that the Hill Assist has gone.
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: Start / Stop Info...
    Sep 2008
    good info.
    thanks.
    I have exactly the same concerns about hill hold as scotty.
    First one to find the answer wins this smiley ->
  4. Re: Start / Stop Info...
    Mar 2009
    Quote Originally Posted by ScottyUK View Post
    Thanks...
    Not too sure how it works, but a reckon it goes a bit like this.
    Start / Stop function ON
    When you pull up to the traffic lights and stop you would put the car into neutral and release to clutch, then you would apply the hand break. The engine would switch off. The lights turn to green and then you dip the clutch to enable you to engage 1st the engine would start. When you release the clutch to set off the hand break would automatically release and you would drive off.
    On the 2.0TDI (143ps) I had for a test drive, the hand break function was great.
    As far as I know the hand break was just the normal electro function one and not the Hill Hold version.
    Normally I would never use the hand break, but I found the system very good.
    This is how it went...
    Pull up to the traffic lights, put the car into neutral and apply the hand break
    Then on the green signal dip the clutch engage 1st and release the clutch to set off. No need to release the hand break manually, just set off.
    Great...
    Maybe BRISTLE HOUND will be able to advise on how a normal hand break works, if different from the above.... !!!!
    Martin
  5. Re: Start / Stop Info...
    Jul 2008
    On my humble '08 B8, the Hill Hold cannot be activated with the engine off and decativates as soon as the engine is switched off...hence I would suspect why Hill Hold is not available with stop start.
    The basic gear change indicator (see it is trumpeted as part of the eco kit)was I thought laughable ...until I found myself following it with unhealthy interest after a few months... Found myself each morning seeing the max mpg I could get...very sad but true.
    First step I guess on the gradual road to the hybrids, see they are due with the new A3.
  6. Re: Start / Stop Info...
    Dec 2007
    London/Surrey
    i beat you to it with a post on the A3 thread
    Btw that dash unit is going to be the new A3's.
    COMING SOON: '14 A5 Cabriolet S-line Special edition, Daytona Grey
    CURRENT: 11' A5 S-Line Black Edition Ibis White
    previous: 09' A3 S-line Ibis White
  1. Please Help 1992 Jetta GX 1.6 won't start
    By s32bauer in forum Jetta MK2 - 1984 - 1992
    Last Post: 18-04-2009, 06:33 PM
  2. Few issues... Power loss, strange wiper problem, hard to start!
    By Kris214 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 09:56 PM
  3. help~ 99 A6 1.8T engine start problem
    By bjtupp in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-03-2008, 09:23 PM
  4. Golf MKIII 1996 1.4 WILL NOT START! HELP!
    By serpico267 in forum Golf MK3 - 1993 - 1999
    Last Post: 10-01-2008, 02:10 PM
  5. Audi A4 wont start
    By carenza in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 03:03 AM
