Thread: vacuum hose
  1. vacuum hose
    Nov 2008
    right need a bit of help was changing my n75 the other day and dropped one of the electrical harness' down the back of the engine and upon retreival i found what looks like a vacuum hose which at this minute in time goes nowhere!
    its right at the back of the engine and has the rubber hose (approx 4 inches long) then goes into a plastic pipe which seems to go up behind the coolent bottle direction? any idea what this is for or where its meant to go?
  2. Re: vacuum hose
    what is the engine code+
  3. Re: vacuum hose
    Apr 2007
    Lancashire
    This may be the tube for the ECU mounted MAP sensor.
    It connects onto a nipple on the underside of the top boost pipe, approx to the right of the EGR N18 valve (looks like the turbo N75 on underside of top boost pipe).
    This applies if you have the early 97 AFN.
  4. Re: vacuum hose
    Nov 2008
    right it is the afn engine but i have a pipe going to the map as i replaced the old one about 1month ago! this has really got me stumpted!
  5. Re: vacuum hose
    chrismaher2007 Guest
    try take a picture if you can. itll be a lot easier to understand
  6. Re: vacuum hose
    Nov 2008
    ill try and get one 2moro if this rain ever stops! lol
    cheers to everyone with the help
  1. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Vacuum Hose to Airbox (Golf mk4/Bora) 1999
    By Tall Paul in forum Golf MK4 - 1999 - 2004
    Last Post: 03-11-2007, 10:34 PM
  4. Vacuum Hose
    By mo_schino24 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-08-2007, 11:44 AM
  5. vacuum hose replacement
    By Eshrules in forum Chat - Anything with wheels
    Last Post: 07-07-2007, 08:21 AM
