Thread: Want to Upgrade Speakers in an '06 A4
  1. Want to Upgrade Speakers in an '06 A4
    Mar 2007
    I have an A4 Avant ('06) and wish to upgrade the standard speakers as I'm not lucky enough to of ended up with the BOSE system.
    Can anybody recommend a company that either sells or fits suitable speaker kits? Happy to keep the existing amp and stereo. I'm in England, Northamptonshire.
    Thanks in advance to any advice.
    Kent
    The speakers in the front and rear are 6.5", most manufacturers will do an upgraded set that are a direct replacement or you can go for a higher range set. I put a set of Alpine SPR17LS component speakers into a Skyline the other day and they sounded superb, you can pick these up for around the £90 mark. If you were bit closer to me I would do them for you, the only place I know up your way is Ice Direct in Peterborough though not sure how far that is from you.
    Hope this helps
  3. Thanks
    Mar 2007
    Thanks for the info, I'll ask for a quote.
    banbury,oxon
    you could always fit the speakers from the bose system??
    B5 passat needs a supercharger and does'nt leak
  5. if only
    Mar 2007
    Bit of an overkill that, using the exisiting amp, isnt it? Way more expensive too I'd imagine. I've got to convince the misses ;-) so under 100 will help with that too.
  1. 4 speakers or 6?
    By judderman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-04-2007, 09:42 PM
  2. car speakers
    By welshdragon1611 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-01-2007, 02:11 PM
  3. Where are all the speakers ?
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 21-01-2007, 01:59 AM
  4. A4 Dodgy Speakers - Speaker Upgrade
    By Mairtin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2007, 02:02 PM
  5. Door Speakers - Help!
    By Maddoggaz in forum 80 - 90
    Last Post: 20-01-2006, 02:19 PM
