Thread: Starting Problems with Golf
  1. Starting Problems with Golf
    Mar 2007
    I dont know if anyone can help me. I have a 2001 1.9 diesel TDi and am having huge problems starting my car.
    It turns over but takes at least 4 attempts to fire and when it does fire there is a huge amount of diesel smoke which is omitted from the car. If the car is hot however it fires immediately its just when it has been standing for a period of time. The glow plugs have been replaced and I still have a problem.
    Anyone any ideas what else it could be?
    Mar 2007
    Yorkshire
    Could be a battery thats on its last legs dude.
    Mar 2007
    The battery is fine but thinking it could be the fuel injection sensor, out my depth to be honest, been in garages and no-one seems to be able to diagnose the problem. Going to book into VW specialist next week
    Feb 2005
    Selby, North Yorkshire
    Hi mate
    It may sound obvious, but have you checked for an air leak on the fuel side of things. It's common for pipes connected to the fuel filter to let air into the fuel lines when the car is stood for a while and then it takes a while for the system to bleed itself when you start it up.
    The air in the system causes the ECU to direct the injectors to input more fuel and hence the excessive smoke and stink of unburnt fuel - or so I'm told!
    Check pipe connections on fuel filter and if they're wet you may have a leak.
    Could also be temp sensor or MAF problem.
    HTH
    Paul
  1. Golf 4 Tdi 130 Starting / Cut out problems
    By WinstonW in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2007, 10:43 PM
  2. MK 4 Golf starting problems
    By berksboy26 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 12:55 AM
  3. mk 3 golf starting problems
    By tward11 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 09:18 PM
  4. Problems with Starting on Golf TDI
    By SLH in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-03-2007, 08:51 AM
  5. Golf Mk3 GTi starting problems...
    By Jonster 8v '92 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-03-2007, 02:52 PM
