Thread: Replacement gearbox problem
Results 1 to 10 of 10
  1. Replacement gearbox problem
    stonkin Guest
    HELP Anyone
    In Short I had a problem with my gearbox ,on VW polo 1.4 2 door (I think a 6N) 1996 model so I purchased a full car to break for a replacement gearbox (I think 6N2) 4 door year 1998 ,here's were my problem started changed the gearbox & clutch no problem,gear selection Linkages were diiferent PROBLEM originally rod & cable (could not get reverse no how but seemed to locate OK) the replacement box had 2 cables for gear selection & a mechanism attached to the box so I changed this & selection box hopefully to cure this only to find the fixing point on the subrame for the cables was not on mine.I would like to use the rod & cable method but does not seem possible with the reverse gear fault.My only thought now would be to weld the fixing points for the cables on the subframe as originally on the spares car (although this is now scrapped)I know this is an unusual problem Hope fully I wont have to go down the line of another gearbox,any thoughts or help appreciated
  2. Re: Replacement gearbox problem
    Oxford, The Shire
    sounds like you need to find yourself a decent engineer!
  3. Re: Replacement gearbox problem
    May 2009
    rhodesia, nottinghamshire
    Hiya mate,
    if your confident that it will work ok then tack weld the bracket in place, if it works weld it up, if not and you have to move it then you only need to grind the tack weld off..
    steve
  4. Re: Replacement gearbox problem
    131 Post(s)
    1974 Post(s)
    It is extremely difficult to change the car from early to late system, you have to swap everything over, this is something that catches out a lot of people.
  5. Re: Replacement gearbox problem
    stonkin Guest
    Thank you for the reply & taking the time to answer,unfortunately it looks like I am one of those people.Looks like a search for an older box or break this car also.I have plenty of parts going cheap if any one is interested.Thanks again
  6. Re: Replacement gearbox problem
    stonkin Guest
    Thank you for the reply & taking the time to answer.I will have a go & see what happens
  7. Re: Replacement gearbox problem
    131 Post(s)
    1974 Post(s)
    I may be breaking an early 1.3 with rod/cable but we haven’t decided on its fate yet.
  8. Re: Replacement gearbox problem
    stonkin Guest
    OK
    Thank you,I will wait for the outcome not sure which way I will go yet ,repair or break
  9. Re: Replacement gearbox problem
    Jun 2009
    birmingham
    hello ino its late but i done this swop on my 1.3 with the 1.4 box from a newer car what you have to do is cut the lug off that is in the way so if you can get under the car and let someone try and get reverse and ul see what lug is in the way its easy to do.hope it helps prob to late dow lol
  10. Re: Replacement gearbox problem
    stonkin Guest
    Thanks for that & this info makes sense,I did check the underneath & so it catching the box when reverse was selected but rather than grind the lug off I changed the rod linkage to cable & used all the ancillaries that the new box had.The gearbox now works as it should.Many thanks for all your help on this very useful site
  1. sharan vr6 auto gearbox problem
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 30-06-2008, 10:04 PM
  2. 1.6 Gearbox Problem, Advice Needed Urgently...
    By alex350r in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2008, 09:53 PM
  3. a4 6speed gearbox problem??
    By james a4 in forum Audi A4 - Archive Topics
    Last Post: 20-09-2007, 11:11 PM
  4. Golf mk3 gearbox problem (probably common)
    By Basscrazy in forum Golf MK3 - 1993 - 1999
    Last Post: 22-08-2007, 09:54 AM
  5. A4 TDI Multitronic GEARBOX Problem HELP!
    By bluedna in forum Audi A4 - Archive Topics
    Last Post: 18-02-2007, 11:03 PM
