Hi all,
Typical, you solve one problem and then another one appears. Went to pick up the new charge hose today and on the way back I noticed that the temp gauge dropped to 80C, then rose again after about 10mins back to 90C. Since then it is going up and down between 60C and 80C seemingly at random. I am assuming that it is the sender that is U/S?? Will this affect the engine in any way, eg fuel consumption? Fuel consumption has dropped since the new hose has been fitted, back up to 45 mpg at the moment and hopefully will continue rising.
