Thread: BMP engine specs
  1. BMP engine specs
    Dec 2008
    Hello all,
    I have a VW Passat 2.0 TDI DPF 140bhp, with BMP engine...
    need help on engine torque specifications, for this...
    I can't find it on autodata.... only BKP engine, and not BMP like mine!
    any information is welcome!!
  2. Re: BMP engine specs
    Jul 2008
    Its 235lb/ft
    Look here for it referanced in the listings: http://atp-tuning.at/shop_content.php?coID=14
    A4 Avant 2.0 TDI 170 S-line Exec - Aruba Blue, 18" alloys, Full Sline Drop, Full Leather, MMI Hi, Phone Prep High, AMI, DAB, Adaptive Lights, Folding Mirrors, Power Tailgate, Light & Storage Packs, Parking Plus, Auto Hold, Adaptive Cruise, Lane Assist, Heated Sports Seats with Memory, Rear Blinds, Privacy Glass, Rear Airbags, TPMS, Load Liner.
  3. Re: BMP engine specs
    Dec 2008
    Thanks, but I was refering to more technical specifications... the screws torque in the engine (crankshaft, etc,...)
    If you still know where can I find it, please advise!
  4. Re: BMP engine specs
  5. Re: BMP engine specs
    May 2009
    Essex
    Cypher
    Assuming the only difference between the BKP and BMP is the DPF, then I would have thought the torque settings for the various nuts and bolts in the engine would be the same.... obviously there will be no information for the DPF itself .... but the BKP specs should cover most of your needs.
    Are you planning some serious maintenance? If so, I salute you, I certainly have neither the time or courage to take apart a modern diesel engine.
    Tony
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. GOLF GTI MK3 2.0 16V ABF engine change
    By mo_schino24 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2008, 12:04 AM
  3. black smoke
    By becaela in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 12:19 AM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
