Thread: Fault Code 01135
  1. Fault Code 01135
    Apr 2009
    Hi Everyone.
    This is my first post so here we go.
    Took delivery of the full version of VCDS this morning .
    Awesome bit of kit. Done a full scan on my 2003 Bora TDI 130.
    No problems except for one fault code which was
    Address 46: Central Conv.
    Control Module Part Number: 1C0 959 799 B
    Component and/or Version: 6G Komfortgerát HLO 0003
    Software Coding: 00258
    Work Shop Code: WSC 01266
    Additional Info: 1C2959802A 6G Tőrsteuer.FS KLO 0009
    Additional Info: 1C2959801A 6G Tőrsteuer.BF KLO 0009
    Additional Info: 1C0959811A 6G Tőrsteuer.HL KLO 0009
    Additional Info: 1C0959812A 6G Tőrsteuer.HR KLO 0009
    1 Fault Found:
    01135 - Interior Monitoring Sensors
    36-00 - Open Circuit.
    Is there any other checks I can do on VCDS to futher investigate the fault.
    Or is it just a case of replaceing the sensors.
    Keep up the good work everyone.
  2. Re: Fault Code 01135
    Southern County Softy
    20 Post(s)
    Save the scan, clear the fault and see if it comes back after a couple of days..
    A4 2.5 tdi QS (mapped)
  3. Re: Fault Code 01135
    134 Post(s)
    2021 Post(s)
    Common problem, new sensors required and Ł110 each.
  4. Re: Fault Code 01135
    Apr 2009
    Thanks Guys.
    I`ve cleared the fault code so I`ll see what happens.
    Thats a lot of lolly crasher.
    Would the 2 sensors be U.S or is there a way of checking which
    one it would be on VCDS.
  5. Re: Fault Code 01135
    134 Post(s)
    2021 Post(s)
    Very difficult to decide which is faulty.
  6. Re: Fault Code 01135
    Apr 2009
    Thanks again O Mighty One (crasher)
    I`ll get one sensor first and go from there.
  1. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  2. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  3. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  4. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
  5. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
